I have been trying to install the Newznab+ on my QNAP P219+ and I'm running into an issue running some PHP scripts.
This is the error I get when I attempt to run
php update_binaries.php
PHP Warning: require_once(PEAR.php): failed to open stream: No such file or directory in /share/MD0_DATA/Web/www/lib/Net_NNTP/NNTP/Protocol/Client.php on line 73 PHP Fatal error: require_once(): Failed opening required 'PEAR.php' (include_path='.:') in /share/MD0_DATA/Web/www/lib/Net_NNTP/NNTP/Protocol/Client.php on line 73
Any help would be appreciated
