[ QJDK8 ] [ 1.8.333 ] Java Development Kit (dependency)
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
Download QJDK8: x86, x64, arm64, x31, x41
https://www.myqnap.org/product/qjdk8/
Java Dev Kit 8 for apps requiring it
About :
Dependency for apps requiring it
Last edited by QNAP_Stephane on Sat Oct 29, 2022 5:44 pm, edited 11 times in total.
Moogle Stiltzkin
Contact:
Re: [ QJDK8 ] [ 1.8.31 ] Java Development Kit (dependency)
Post by Moogle Stiltzkin »
ty steph.
apparently some were looking for it, i helped mention it :}
http://forum.qnap.com/viewtopic.php?f=1 ... 69#p506069
NAS
Network
Resources
mrs4t4n
Know my way around
Post by mrs4t4n »
Thanks for this QPKG.
If an app requires 1.7, will it works only with 1.8 installed? or i need to have both installed and running?
Thanks!
QNAP_Stephane
Experience counts
both can be installed side by side ;)
it is not in NAS PATH, so no conflict, you need to export JAVA_HOME to right directory
bry
Know my way around
Post by bry »
I don't believe this package is running on my qnap - can you help me confirm and correct so I may use the wonderful subsonic package that you so kindly created after I requested.
QNAP_Stephane
Experience counts
bry wrote:I don't believe this package is running on my qnap - can you help me confirm and correct so I may use the wonderful subsonic package that you so kindly created after I requested.
just install it, and check is well on...
nothing to do...
QSubsonic use it automatically ...
bry
Know my way around
Post by bry »
nothing to do...
it is installed, I don't believe that it is running based on the error that subsonic throws when trying to start.
./subsonic.sh: line 121: java: command not found
QNAP_Stephane
Experience counts
you mean it doesnt start autoatically from QTS ?
it is using port 4040 by default --> dont you have an application already using it ?
try /etc/init.d/QSubSonic.sh start instead
no issue here on several NAS.. x53, x51
bry
Know my way around
Post by bry »
/share/MD0_DATA/.qpkg/QSubSonic$ /etc/init.d/QSubSonic.sh start
Started Subsonic [PID 23188, /share/MD0_DATA/.qpkg/QSubSonic/subsonic_sh.log]
results in: ./subsonic.sh: line 121: java: command not found
I don't think its starting from package center.
QNAP_Stephane
Experience counts
can you check if in /opt you have well a QJDK8 symlink ?
with : " ll /opt"
that a bit weird..
bry
Know my way around
Post by bry »
QNAP_Stephane wrote:can you check if in /opt you have well a QJDK8 symlink ?
with : " ll /opt"
that a bit weird..
what is the exact path ?
QNAP_Stephane
Experience counts
/opt/QJDK8 must be a symlink pointing to your /share/MD0_DATA/.qpkg/QJDK8 path
in SSH doing a 'll /opt' it should display all content and where it is pointing
bry
Know my way around
Post by bry »
[~] # ll /opt
lrwxrwxrwx 1 admin administ 29 May 5 15:06 /opt -> /share/MD0_DATA/.qpkg/Optware/
QNAP_Stephane
Experience counts
you still using optware.. should be removed... very insecure
my opiinion your NAS has issue
you should have other symlink here
bry
Know my way around
Post by bry »
QNAP_Stephane wrote:you still using optware.. should be removed... very insecure
optiware removed.
next steps to correct please?
how can I check and/or/edit the symlinks please?
Return to “Community Apps”
