[ QMineCraft ] [ 1.19.3.0] MineCraft Server
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
TimRideout
Know my way around
Contact:
Re: Qminecraft - how to OP the first user
Post by TimRideout »
Thanks Silent Bob - to be clear: do I leave the square brackets ( These guys>> [] <<< )in or out of my paste?
T
SilentB0b wrote: Wed Apr 08, 2020 3:01 am
TimRideout wrote: Fri Apr 03, 2020 10:57 am HI all,
I have been spending ALL eve on this one- I installed the excellent QmineCraft QPKG on my QNAP (thanks!) - but how the HECK do I make myself an operator?
I have tried modifying the SERVER OPS file, by the procedure listed here:
https://pastebin.com/Fbsj9v47
But open modification and restarting the server, I can no longer connect.
For now, I am only going over my LAN.
Can someone tell me *exactly* how to make myself an Operator?
Thanks!
It took me ages to figure this one out, and I'm only really halfway there, I ended up copying the ops.json from another server I'm Op on which worked.
In the Web UI open the Server Opps tab and enter the following info, edited with your details
    "uuid": "Your UUID between the quotation marks",
    "name": "Your minecraft name",
    "level": 4,
    "bypassesPlayerLimit": false
to find your UUID I found this site, use the Full UUID
https://mcuuid.net/
Scroll to the bottom of the page and click Modify.
You'll now need to restart the Minecraft services, easiest way I found was to simply reboot the Qnap, once it's back up connect to the world in Minecraft and test if you are able to switch gamemodes
TimRideout
Know my way around
Contact:
Re: [ QMineCraft ] [ 1.15.2.0 ] MineCraft Server
I have tried everything. It's still not working. I am giving up... thanks for your help!
TimRideout
Know my way around
Contact:
PS SAVE YOURSELVES
RUN AWAYYYYYY
But seriously- there is WAY too much hacking to do; and even at that, the server stil doesnt work. Sorry... it was a good effort and I'm sure took quite some time!
Tralkar
First post
Post by Tralkar »
It's not working for me, anyone solution? I found that on this minecraft download site https://pobierajgry.pl/gry/minecraft-download/ everything is working
myles@boyd.network
Post by myles@boyd.network »
Installed the QNAPClub 1.15.2.0 onto TS-431P and checked that it's running but on the QNAP desktop if I click the Minecraft Server button it throws up "This site can’t be reached"
Address is https://192.168.xxx.xxx:8081/QMineCraft tried just http as well.
Any ideas?
fixed it - didnt - didnt like 8081 - changed https on the web server 8082
Last edited by myles@boyd.network on Tue Jun 23, 2020 11:56 pm, edited 1 time in total.
dolbyman
Post by dolbyman »
no need to censor private addresses
is your webserver running ?
myles@boyd.network
Thanks for quick response - fixed the web browser issue BUT the clients report its old. any ideas
dolbyman
Post by dolbyman »
never used it, if it's old and you are using the latest release available, contact Qnap_Stephane and ask if he can update the built
QNAP_Stephane
Experience counts
Re: [ QMineCraft ] [ 1.16.0 ] MineCraft Server
Post by QNAP_Stephane »
updated
HUFChris
Post by HUFChris »
Can anyone help get the 1.16.1 version. This version will no longer work or let me connect as it says its out of date on the server?
QNAP_Stephane
Experience counts
Re: [ QMineCraft ] [ 1.16.1 ] MineCraft Server
updated
HUFChris
Post by HUFChris »
Brilliant, thank you so much.
djepps
Post by djepps »
Does anybody else experience frequent glitches and crashes due to "Player" moved too quickly? Typically I am on a horse, but sometimes when running. I am on a TVS-471 (i3-4150 @3.5GHz) with 8gb and have increased the ram in the QMineCraft.sh file to Xmx4096M -Xms2048M. I have also Enabled flight to try to solve the problem without success. It is survival with no mods i.e. Vanilla. In previous versions maybe 1.14 and before, I didn't have much a problem but ever since 1.15 I have run into it. It also is impossible to fly with Elytra which stinks after all the hard work to acquire Elytra in survival/vanilla server. I have the settings such as distance render and such on default. Also, it happens both when there is one player and up to five players in the world. Appreciate any thoughts or help. Thank you.
hardmack
Post by hardmack »
332x, I can not seem to get either the dependent JDK to install and the qpkg for Minecraft, either. I am extremely new to the qnap infrastructure but I would love to get this going for my kids.
QNAP_Stephane
Experience counts
Arm64 exist for both qpkg
Envoyé de mon MI 9 en utilisant Tapatalk
Return to “Community Apps”
