[ QMineCraft ] [ 1.19.3.0] MineCraft Server
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
Source : https://minecraft.net/download
Download :
https://www.myqnap.org/product/minecraft-server/
Dependency :
QJDK17 : https://www.myqnap.org/product/qjdk-17/
Port to open :
Server port : 25565
Last edited by QNAP_Stephane on Fri Feb 17, 2023 11:34 pm, edited 35 times in total.
sirik
Re: [ QMineCraft ] [ 1.8.4 ] MineCraft Server
Post by sirik »
He There, do you have a version that's compatible with a Qnap TS-419P+
Thnx
QNAP_Stephane
Experience counts
sirik wrote:He There, do you have a version that's compatible with a Qnap TS-419P+
Thnx
I have to check, but it should be feasible ...
sirik
Post by sirik »
Did you had time to check ?
QNAP_Stephane
Experience counts
not yet checked, i will do it this week, if i have some minutes to test on an office NAS
QNAP_Stephane
Experience counts
Re: [ QMineCraft ] [ 1.8.7 ] MineCraft Server
Updated to 1.8.7 ;)
wouter1971
Post by wouter1971 »
@QNAP_Stephane: Thanks man works instantly!
iansmiler
Post by iansmiler »
Hi! I have a TS-470 Pro and I'd love to run a minecraft server so I could play with my kids on it :)
I am however - useless with Linux! What exactly would I need to do to get one running on there?
Any help appreciated - Ian
iansmiler
Minecraft Server - HELP!
Post by iansmiler »
Hi! I have a TS-470 Pro and I'd love to run a minecraft server so I could play with my kids on it :D
I am however - useless with Linux! :-0 What exactly would I need to do to get one running on there?
Any help appreciated - Ian :shock:
QNAP_Stephane
Experience counts
Re: [ QMineCraft ] [ 1.8.8 ] MineCraft Server
updated to 1.8.8
MrJinggles
First post
Post by MrJinggles »
Hi!
First of all, thank you! The servers works perfectly on my 453-Pro.
I have just one issue, I can´t access the WebGui on port 11400.
It says, that the connection was refused.
My Webserver is turned on by the way.
Thanks and br!
QNAP_Stephane
Experience counts
if you have 4.2 it is normal, i need update it
no need have webserver activated to make it runs, it launchs another apache process
tafel
Post by tafel »
Stephane, it'd be awesome if you could look into Cuberite, the former MCServer. It is a C++ minecraft server.
It runs on a raspberry pi, so hopefully it could run on a QNAP nas too...
Unfortunately they are using a recent version of C++, so you need GCC v4.8.
I opened a thread here.
QNAP_Stephane
Experience counts
tafel wrote:Stephane, it'd be awesome if you could look into Cuberite, the former MCServer. It is a C++ minecraft server.
thanks for notification, with actual glibc i can grow up to gcc 4.3.6
i think it will be feasible for 64bit enable NAS ;)
tafel
Post by tafel »
QNAP_Stephane wrote:i think it will be feasible for 64bit enable NAS ;)
In other words ... impossible on TS-412 :) ? But cuberite offers a 32-bit mode for compilation...
Edit: nvm. I'll give it a shot with qnapware.
Return to “Community Apps”
