[ OsCAM ] [ 1.20.11717 ] Card Server
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
Source : http://download.oscam.cc/index.php / https://github.com/gfto/oscam
Download :
https://www.myqnap.org/product/oscam/
Note :
config file editable within webui app
admin / admin (default credential)
About :
[ http://www.streamboard.tv/wiki/OSCam/fr/What_is_OSCam ]
OScam is a softcam, software to be used to decrypt digital television channels on a settopbox (receiver), as an alternative for a conditional access module (CAM). OScam is, compared with other softcams (CCcam, mgcamd, etc.), open source. Hence, the name Open Source Conditional Access Module (OScam). OScam is based on the not so well known softcam MpCS. The main features of OSCam are next to its softcam capabilities, that it is able to function as a cardserver.
Last edited by QNAP_Stephane on Sun Dec 25, 2022 12:22 am, edited 26 times in total.
killer8
Know my way around
Re: [OsCAM ] [ 1.20.10660 ] Card Server
Post by killer8 »
Does this support Anysee tv tuners?
QNAP_Stephane
Experience counts
killer8 wrote:Does this support Anysee tv tuners?
I think best way to know is to test... you can find also information on OsCAM forum for differents configurations
i dont have this stuff under my hands here... :wink:
wouter1971
Post by wouter1971 »
Hi QNAP_Stephane, thank you very much for this qpkg package. Easy to configure too. Works brilliantly.
I see you have logging turned off to make it possible for the disks to spindown. Does that work? I'm not really convinced about that.
For now it's ok that tv and nas are on both to watch tv. Hope you can update the package as well in the future, that would be great!
Thanks again.
QNAP_Stephane
Experience counts
I am not monitoring all application update, but ping me and i will update it ;)
QNAP_Stephane
Experience counts
Re: [OsCAM ] [ 1.20.10991 ] Card Server
update + arm versions
foz111
Getting the hang of things
Post by foz111 »
hi
I've just ordered a new Qnap ts-253 pro, not arrived yet, I see it has the Intel® Celeron® 2.0GHz quad-core processor, what version of oscam will I need to run on this box with this processor, or do I need to compile it on the nas?
can I run both smargo and omnikey like I do on my centos server?
thanks
foz
QNAP_Stephane
Experience counts
X86 version will work
foz111
Post by foz111 »
thanks for your reply
will the firmware on the nas v4.2.0-20151023 be 32 bit or 64 bit I am struggling to find this information?
thanks again
once installed where are the config's located? thanks
QNAP_Stephane
Experience counts
x64 depend of your NAS
all models doesnt have all libs embedded in /lib64
for example x53 series libs are patial while on series x80 you will find all lib
I heard R&D scheduled to turned all models to full x64 around 4.2.2
foz111
Post by foz111 »
I used the above file for the x86 box for now and its working thanks
starting to get my head around this now a little.
I've found the configs in /share/CACHEDEV1_DATA/.qpkg/OsCAM/etc great
just wondered why the settings in /mnt/HDA_ROOT/.config/qpkg.conf point to the webport 12478 is this an outside port to be opened if you require access from outside lan? I expected this to be pointing to local 8589 port set for webif in oscam.conf? so when I click on the icon on qnap desktop it opens webif.
WebUI = /
Web_Port = 12478
[webif]
httpport = 8589
thanks
TS-253D
QTS 5.0.1.2376 Firmware
NestorB
Post by NestorB »
Hi QNAP_Stephane !
Thanks for your package !
I have a QNAP TS-453 PRO NAS.
I got an issue with last release 1.20.10991 and my gemplus smartcard reader.
I identified why. The pcsc option was disabled.
After replacing by 1.20.10660 release that works !
Can we get the new release with this option and DVB API enabled ?
Because I would like to use it for TVHeadEnd and KODI.
Else how can I compile the last OSCAM source with these settings enabled ?
Thanks for your help.
QNAP_Stephane
Experience counts
i will check for update, but not sure how i can embedd DVB API
to compile you need to use a toolchain, but this version is based on precompiled binaries
QNAP_Stephane
Experience counts
Re: [OsCAM ] [ 1.20.11222 ] Card Server
updated ;)
NestorB
Post by NestorB »
Thanks QNAP_Stephane !
My card reader PCSC works with my Orange card!
I would like to use DVB API for communication between OSCAM and TVHeadEnd and KODI.
How Should I do ?
I have to use newcamd maybe.
But what settings I need for each applications ?
QNAP TVS-473 - 32Go - WDC WD30EFRX (3To) x 4 - RAID 5 - QTS 4.4.1
Return to “Community Apps”
