[ Bind DNS ] [ 9.14.8.0 ] DNS Server
- QNAP_Stephane
source : https://www.isc.org/downloads/bind/
download :
https://www.qnapclub.eu/fr/qpkg/267
Note :
since 4.3.5, Qnap firmware is using dnsmasq bridged to resolv.conf and using port 53 by default, you need to tweak configuration to make bind works properly
Backup your config before update
config files within /opt/Bind/etc (stop application within appcenter before config modification)
About :
BIND is open source software that implements the Domain Name System (DNS) protocols for the Internet. It is a reference implementation of those protocols, but it is also production-grade software, suitable for use in high-volume and high-reliability applications. The name BIND stands for “Berkeley Internet Name Domain”, because the software originated in the early 1980s at the University of California at Berkeley.
BIND is by far the most widely used DNS software on the Internet, providing a robust and stable platform on top of which organizations can build distributed computing systems with the knowledge that those systems are fully compliant with published DNS standards.
Last edited by QNAP_Stephane on Wed Nov 27, 2019 3:30 am, edited 3 times in total.
- QNAP_Stephane
Re: [ Bind DNS ] [ 9.11.0.0 ] DNS Server
updated + x64 version
Is this version is compatible with QTS 4.3?
I just installed qts 4.3 and my bind 9.11 stopped working, it won't start. Is there a way to make it works with this version? Im using BIND from the QNAP CLUB, I saw on your site it's compatible with 4.2. 1 but I upgraded by mistake.
Can you help me please?
- Trexx
Did you install the x64 version of the QPGK listed above once you went from 32-bit QTS 4.2 to 64-bit QTS 4.3?joblain wrote:Is this version is compatible with QTS 4.3?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I tried but it failed and i dont know how to check why.
- QNAP_Stephane
did you remove it first ? (backup your config)
and reinstall 64bits version, if install over, 32/64 libs may conflict
Thanks for this! I'm totally new to BIND and really just experimenting with it on my QNAP (TS-251+, QTS 4.3.3.0210) to learn.
I've been able to install it, configure named.conf (based on some things I learned by Googling), and start it up. However, I'm not seeing any logs being generated and the DNS server does not respond (I'm using nslookup and ping from a windows 10 machine after overriding its DNS server to the IP address of my QNAP). The entire contents of my named.conf is below.
Can you point me in the right direction?
My named.conf file:
acl goodclients {
192.168.1.0/24;
localhost;
localnets;
options {
directory "/var/cache/bind";
recursion yes;
allow-query { goodclients; };
dnssec-validation auto;
auth-nxdomain no; #conform to RFC1035
listen-on-v6 { any; };
My named.conf file:
acl goodclients {
192.168.1.0/24;
localhost;
localnets;
options {
recursion yes;
I was able to figure this out. It was basically because I have no idea what I'm doing. I understand now that my named.conf needed to include more information (including references to root servers). Once I learned more about what needed to be in there, it all started working properly. Thanks!
- QNAP_Stephane
Re: [ Bind DNS ] [ 9.11.2.0 ] DNS Server
updated
I install Bind package in my QNAP but could not start named daemon.
I got the bellow error
[/opt/Bind] # bin/named -g -p 53
15-Aug-2019 11:38:02.372 starting BIND 9.11.2 <id:0a2b929>
15-Aug-2019 11:38:02.372 running on Linux x86_64 3.4.6 #1 SMP Tue Jul 30 13:03:29 CST 2019
15-Aug-2019 11:38:02.372 built with '--prefix=/opt/Bind' '--host=x86_64-QNAP_FW43-linux-gnu' '--sysconfdir=/opt/Bind/etc' '--localstatedir=/opt/Bind/var' '--mandir=/opt/Bind/share/man' '--enable-threads' '--with-libtool' '--disable-static' '--with-geoip=/opt/Bind' '--with-openssl=/opt/Bind' '--with-randomdev=/dev/urandom' '--enable-native-pkcs11' '--enable-querytrace' '--with-gost' 'host_alias=x86_64-QNAP_FW43-linux-gnu' 'CC=x86_64-QNAP_FW43-linux-gnu-gcc' 'CFLAGS=-O2 -I/opt/Bind/include ' 'LDFLAGS=-L/opt/Bind/lib -Wl,-rpath,/opt/Bind/lib' 'CPPFLAGS=-O2 -I/opt/Bind/include'
15-Aug-2019 11:38:02.372 running as: named -g -p 53
15-Aug-2019 11:38:02.372 ----------------------------------------------------
15-Aug-2019 11:38:02.372 BIND 9 is maintained by Internet Systems Consortium,
15-Aug-2019 11:38:02.372 Inc. (ISC), a non-profit 501(c)(3) public-benefit
15-Aug-2019 11:38:02.372 corporation. Support and training for BIND 9 are
15-Aug-2019 11:38:02.372 available at https://www.isc.org/support
15-Aug-2019 11:38:02.372 adjusted limit on open files from 4096 to 1048576
15-Aug-2019 11:38:02.372 found 4 CPUs, using 4 worker threads
15-Aug-2019 11:38:02.372 using 3 UDP listeners per interface
15-Aug-2019 11:38:02.373 using up to 4096 sockets
Can't load PKCS#11 provider: dlopen("undefined") failed: undefined: cannot open shared object file: No such file or directory
15-Aug-2019 11:38:02.374 initializing DST: no PKCS#11 provider
15-Aug-2019 11:38:02.374 exiting (due to fatal error)
Does anyone know how to fix this issue?
I have the same "Can't load PKCS#11 provider" error.
Did you ever find a solution?
- QNAP_Stephane
i need to double check.... can you please provide NAS and version... since 4.3.x port 53 is used by virtualswitch and dnsmasq bind , not sure it is related
I have same issue.
NAS model: TVS-473
QTS version : 4.4.1.1117
[/opt/Bind] # ./bin/named -g -p 53
24-Nov-2019 17:07:20.606 starting BIND 9.11.2 <id:0a2b929>
24-Nov-2019 17:07:20.606 running on Linux x86_64 4.2.8 #1 SMP Sat Nov 9 07:59:18 CST 2019
24-Nov-2019 17:07:20.606 built with '--prefix=/opt/Bind' '--host=x86_64-QNAP_FW43-linux-gnu' '--sysconfdir=/opt/Bind/etc' '--localstatedir=/opt/Bind/var' '--mandir=/opt/Bind/share/man' '--enable-threads' '--with-libtool' '--disable-static' '--with-geoip=/opt/Bind' '--with-openssl=/opt/Bind' '--with-randomdev=/dev/urandom' '--enable-native-pkcs11' '--enable-querytrace' '--with-gost' 'host_alias=x86_64-QNAP_FW43-linux-gnu' 'CC=x86_64-QNAP_FW43-linux-gnu-gcc' 'CFLAGS=-O2 -I/opt/Bind/include ' 'LDFLAGS=-L/opt/Bind/lib -Wl,-rpath,/opt/Bind/lib' 'CPPFLAGS=-O2 -I/opt/Bind/include'
24-Nov-2019 17:07:20.606 running as: named -g -p 53
24-Nov-2019 17:07:20.606 ----------------------------------------------------
24-Nov-2019 17:07:20.606 BIND 9 is maintained by Internet Systems Consortium,
24-Nov-2019 17:07:20.606 Inc. (ISC), a non-profit 501(c)(3) public-benefit
24-Nov-2019 17:07:20.606 corporation. Support and training for BIND 9 are
24-Nov-2019 17:07:20.606 available at https://www.isc.org/support
24-Nov-2019 17:07:20.606 adjusted limit on open files from 4096 to 1048576
24-Nov-2019 17:07:20.606 found 4 CPUs, using 4 worker threads
24-Nov-2019 17:07:20.606 using 3 UDP listeners per interface
24-Nov-2019 17:07:20.607 using up to 4096 sockets
24-Nov-2019 17:07:20.607 initializing DST: no PKCS#11 provider
24-Nov-2019 17:07:20.607 exiting (due to fatal error)
[/opt/Bind] # netstat -paunt | grep 53
netstat: showing only processes with your user ID
tcp 0 0 127.0.1.1:53 0.0.0.0:* LISTEN 6252/dnsmasq
tcp 0 0 10.0.5.1:53 0.0.0.0:* LISTEN 6252/dnsmasq
tcp 0 0 10.0.3.1:53 0.0.0.0:* LISTEN 6252/dnsmasq
tcp 0 0 10.8.0.1:53 0.0.0.0:* LISTEN 6252/dnsmasq
tcp 0 0 10.6.0.1:53 0.0.0.0:* LISTEN 6252/dnsmasq
tcp 0 0 192.168.1.1:49153 0.0.0.0:* LISTEN 29454/qDmcd
tcp 0 0 0.0.0.0:3493 0.0.0.0:* LISTEN 2253/upsd
tcp 0 0 192.168.1.4:43390 139.59.128.245:443 ESTABLISHED 18653/tunnelagent
udp 0 0 127.0.1.1:53 0.0.0.0:* 6252/dnsmasq
udp 0 0 10.0.5.1:53 0.0.0.0:* 6252/dnsmasq
udp 0 0 10.0.3.1:53 0.0.0.0:* 6252/dnsmasq
udp 0 0 10.8.0.1:53 0.0.0.0:* 6252/dnsmasq
udp 0 0 10.6.0.1:53 0.0.0.0:* 6252/dnsmasq
udp 0 0 0.0.0.0:53662 0.0.0.0:* 6252/dnsmasq
udp 0 0 0.0.0.0:5353 0.0.0.0:* 31584/avahi-daemon:
Do you plan Stephane to release a package for bind 9.14.6 ?
Regards,
Nestor
NAS model: TVS-473
Regards,
Nestor
QNAP TVS-473 - 32Go - WDC WD30EFRX (3To) x 4 - RAID 5 - QTS 4.4.1
- QNAP_Stephane
I will check for update... but hard week start ...
- QNAP_Stephane
Re: [ Bind DNS ] [ 9.14.8.0 ] DNS Server
totaly rebuilt version ( x64 version online) the other will follow
