[ NZBHydra ] [ 0.2.140 ] Meta search for NZB indexers and the "spiritual successor" to NZBmegasearcH
- QNAP_Stephane
Source : https://github.com/theotherp/nzbhydra
x86 Version : http://www.positiv-it.fr/QNAP/APP/NZBHy ... 6.qpkg.zip
x64 Version : http://www.positiv-it.fr/QNAP/APP/NZBHy ... 4.qpkg.zip
About :
NZBHydra is a meta search for NZB indexers and the "spiritual successor" to NZBmegasearcH. It provides easy access to a number of raw and newznab based indexers.
Features
Searches Binsearch, NZBIndex, NZBClub, omgwtfnzbs.org, Womble and most newznab compatible indexers (see https://github.com/theotherp/nzbhydra/issues/20 and https://github.com/theotherp/nzbhydra/w ... exer-Hosts )
Search by IMDB, TMDB, TVDB, TVRage and TVMaze ID (including season and episode) and filter by age and size. If an ID is not supported by an indexer it is attempted to be converted (e.g. TMDB to IMDB)
Rudimentary (for now) query generation, meaning when you search for a movie using e.g. an IMDB ID a query will be generated for raw indexers. Searching for a series season 1 episode 2 will also generate queries for raw indexers, like s01e02 and 1x02
Grouping of results with the same title and of duplicate results, accounting for result posting time, size, group and poster. By default only one of the duplicates is shown. You can provide an indexer score to influence which one that might be.
Mostly compatible with newznab search API (tested with Sonarr, CP and NZB 360).
Either proxy the NZBs from the indexers (keeping all X-NZB headers), redirect or use direct links in search results
Included function to add results (single or a bunch) to SABnzbd or NZBGet(v13+) and show NFOs where available. Option to decide if links are added as links or the NZBs are uploaded. Select category in GUI or define a default.
Statistics on indexers (average response time, share of results, access errors), NZB download history and search history (both via internal GUI and API). Indexers with problems are paused for an increasing time span (like in sonarr)
Reverse proxy compatible. See https://github.com/theotherp/nzbhydra/w ... erse-proxy
Last edited by QNAP_Stephane on Sun Aug 21, 2016 8:43 pm, edited 4 times in total.
Re: [ NZBHydra ] [ 0.0.1.61 ] Meta search for NZB indexers and the "spiritual successor" to NZBmegasearcH
That's amazing, I just installed it on my QNAP TS-451 along with Sonarr and SABnzbd. Absolutely fantastic I also added 5 Indexers which really pumped it up.
Thank you very much.
- QNAP_Stephane
thanks for your feedback
- RevDrew
Installed on my TVS-471 and so far I like it, very easy to setup and navigate, looks quite polished for being so 'new'.
Thanks for making the package for an easy install, I think this will be very useful.
People laugh because I'm different, I laugh because they're all the same.
- QNAP_Stephane
Arm V7 for x31 is possible i thinkDj_Sim wrote:Please can you make am ARM release?
Nice i used nzbsearch quite a lot on my linux server. Will definitely try this
- QNAP_Stephane
ARM v5 is a headach to cross compile, because Python need a local interpreter, just like Mono and Perl.
for ARM v7 i could build a tool chain inside a chroot on a TS-231 (but so sloooooooow), on ARM V5 the glibc is very very old (2.5.1)
Searching without LXML is dead slow. I have this problem as well in couchpotato. How can i install LXML?
I have the qnap systems python v3.5 installed.
- QNAP_Stephane
lowfi wrote:Searching without LXML is dead slow. I have this problem as well in couchpotato. How can i install LXML?
Where di you see it require lxml ? i can add it with ease.
it runs with his own Python 2.7.11 embedded
It is not mandatory. If you check "http://QNAP:5075/config/searching > Result processing > Type" it is an option.
As far as i understand lxml allows faster parsing of data.
- QNAP_Stephane
Ok i will update to 0.0.1.63 and add lxml to Python
While you are on it....
2016-02-14 11:17:59,003 - INFO - web - Starting update
2016-02-14 11:17:59,006 - INFO - update - Clearing out update folder /share/CACHEDEV1_DATA/.qpkg/NZBHydra/nzbhydra-master/update before extracting
2016-02-14 11:17:59,007 - INFO - update - Creating update folder /share/CACHEDEV1_DATA/.qpkg/NZBHydra/nzbhydra-master/update before extracting
2016-02-14 11:17:59,008 - INFO - update - Downloading update from u'https://github.com/theotherp/nzbhydra/tarball/master'
2016-02-14 11:17:59,244 - ERROR - update - Error while trying to update: [Errno socket error] [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)
- QNAP_Stephane
dont know about this issue...
may be try to install CACert QPKG...
just added lxml.. pyopenssl is already embedded
cffi (1.5.0)
cryptography (1.2.2)
enum34 (1.1.2)
idna (2.0)
ipaddress (1.0.16)
lxml (3.5.0)
pip (8.0.2)
pyasn1 (0.1.9)
pycparser (2.14)
pycurl (7.43.0)
pyOpenSSL (0.15.1)
setuptools (18.2)
six (1.10.0)
