[ FS-UAE ] [ HDStation ] Commodore Amiga Emulator
- QNAP_Stephane
Source : https://fs-uae.net
Download :
HDStation : http://www.qoolbox.fr/FSUAE_1.7.15_x86_64.qpkg.zip
HDStation : http://www.qoolbox.fr/FSUAE_2.8.1.3_x86_64.qpkg.zip
Note :
unzip
install within HDStation and enjoy
to stop application, use disable button within QTS (no exit possbility)
this apps require some integration knowledge :
data files : in the .qpkg/FS-UAE/FS-UAE ---> consider reading documentation before use
Last edited by QNAP_Stephane on Sun Dec 04, 2016 12:31 am, edited 1 time in total.
Re: [ FS-UAE ] [ HDStation ] Commodore Amiga Emulator
I have silly question:
where is default config file and default folder for kickstar and etc folders and files ???
Include doc is useless because this version of fs-uae is installing into hd station container so all default path from doc is not this same in this case.
Any tutorial for qnaps users ??
Please !!
Please !!
Zotac MI553 (Hackintosh), NAS Qnap TS-453mini 6TB RAID5/128GB ssd for system,UPS APC x 2, PJ JVC DLA-X500, PCV screen, in-wall speakers 7.1 by KEF powered by Marantz, SR6011 and Remote Pronto TS9400
- QNAP_Stephane
the default path is in HDStation /opt/FSUAE (chroot)
in NAS standard path /share/CACHEDEV1_DATA/.qpkg/FSUAE (on normal install)
This second path I know but if I put all my necessaary files into /share/CACHEDEV1_DATA/.qpkg/FSUAE/opt/FS-UAE/Kickstarts;Hard_Drives; Configuration etc (config, kicstart rom, disk and floppy files on startup nothing happens - load default A500 setup .
Maybe I'm wrong - Or is there some other config still needed?
I noticed a folder - whether there should be a file configurations is?
If this is to be in the given path:
whether these /opt/FSUAE (chroot)
if these /share/CACHEDEV1_DATA/.qpkg/FSUAE ?
- QNAP_Stephane
if you install http://www.qnapclub.eu/index.php?act=detail&qpkg_id=336 (openssh_hd)
you can SSh directly in HDSTation chroot with (root pass toor) on port 2223
inside the chroot the install path will be /opt/FSUAE .. may be some files to edit to give him the path for your file (i dont have kickstart to test, and my old Amiga 1200 is dead since some years)
OK, thanks for fast answer
Now I know what to do !
Hi !
Any chance for update package ?
Version 1.7.x is old, no audio on my nas
BTW goog job
BTW goog job
- QNAP_Stephane
Last 2.8.1.u3 is available
The links to the zip files are no longer accessible. Is this project still running, or it died?
Is this project still active? I'd like to run FS-UAE on my TS-251A and HD Station with QTS 5.
Is this project still active? I'd like to run FS-UAE on my TVS-h1288X and HD Station with QTSHero 5.SnakeArtworX wrote: ↑Sun Nov 20, 2022 11:10 pm Is this project still active? I'd like to run FS-UAE on my TS-251A and HD Station with QTS 5.
- QNAP_Stephane
need be rebuilt
Is there a chance to get it anytime soon? Since I no longer have any OG Amiga around, I wanted to use my QNAP with HD Station to run some demos and games on TV.
