[ RetroArch] [1.8.4] [ HDStation4 ] program with which you can play many emulators and games
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
bugler921
Re: [ RetroArch] [ HDStation ] program with which you can play many emulators and games
Post by bugler921 » Fri Jul 19, 2019 1:31 am
I was able to get my Logitech F310 working in HD Station by downloading the file referenced in this other post:
viewtopic.php?p=646440#p646440 (quoted below)
QNAP_Stephane wrote:
Fri Nov 24, 2017 7:04 pm
Hi Philippe is totaly right,
I already built this kernel module but never tested it, because i have no Joystick here (but at least insmod is loading them)
file is available here : www.qoolbox.fr/xpad_driver.tgz
I extracted the archive and put the xpad.ko file in the path /lib/modules/ on my QNAP.
See this post: viewtopic.php?p=721115#p721115
napper1237
Post by napper1237 » Thu Nov 21, 2019 11:07 pm
Hi all
Has anyone managed to get the xbox wireless pads working in hdstation apps please?
napper1237
Post by napper1237 » Fri Nov 22, 2019 6:06 pm
Hans0001 wrote:
Sun Apr 23, 2017 3:49 am
QNAP_Stephane wrote:if someone want to test
http://www.qoolbox.fr/XBOXdrv_0.8.8_x86_64.qpkg.zip
log output are published in /share/Public
no need to click on HDSTation Icon, services are launched automatically
Hello Stephane, thanks a lot for your support regarding Retroarch! I have tried the "XBOXdrv" Application: Works perfectly on my TS-251 with XBOX 360 Wireless Controller. Also Retroarch detects the controller and I can use it for playing games.
But sadly Retroarch is not working well in general while playing SNES roms. It hungs a lot. I have checked CPU and RAM during playing with QNAP recource monitor in QTS but both were at max. at 35%. My guess is that Retroarch is not well optimized for HD station because it is not a common use case.
Can anybody run SNES roms in Retroarch with HD station on TS-251 or any other QNAP fluently?
Hi
I am desperate to know how you managed to get your wireless pads working. I have an xbox usb wireless network adapter in the box, the pads just flash not connecting (have installed the driver from stephane). Any help would be really really appreciated.
Thanks x
napper1237
Post by napper1237 » Wed Nov 27, 2019 6:05 pm
If anyone's reading this... Pleeeeeease throw me the last crumb i need...
So now retroarch is seeing and auto-config'ing the xbox360 wireless adapter (yip). However the pad itseld just wont pair. Have tried a couple of different pads and two different Microsoft made wireless adapters (n and g).
Driving me bonkers being so close to resolving it... If anyone has a clue please comment or pm
Thanks all
mturcotte
Post by mturcotte » Wed Feb 05, 2020 11:27 pm
it seems that the download link no longer work. I'd really like to install Retroarch on my TS251+. Can someone fix the broken link or send me the qpkg file?
Thank you,
dolbyman
Post by dolbyman » Wed Feb 05, 2020 11:42 pm
either wait a day or shoot qnapclub a message..their cdn had issues in the past
mturcotte
Post by mturcotte » Thu Feb 06, 2020 5:41 am
I asked, no answer yet but for the meantime i was wondering if anyone could share it? i don't know how big of a file it is though..
I have another question while i'm at it. I have Xbox one wireless controllers and I also have the PC wired Xbox 360 controllers, but my TS251+ is in my basement and I plan on playing in the living room. I dont think that the wireless controllers would work, and i don't want to route two usb cables throughout the whole house to the TS251. I do have some cat5 plugs available behind the tv thought, does a usb-cat5 to cat5-usb converter exist? and would that work/be compatible ?
Thank you,
EDIT : Link works now. thank you,
mturcotte
Post by mturcotte » Mon Feb 10, 2020 1:11 am
I'm currently stuck, I installed retroarch and Xboxdrv, my xbox360 PC usb controller is connected (the dial has 1/4 circle green light showing meaning it should be working) but it doesn't work. Seems to me like the wired USB pc controller is not compatible with the driver?
When retroarch boots i see a message "100% Xbox wireless receiver (1118/1817) not configured"
Anyone has a clue why and what to do to get this working?
Thank you,
QNAP_Stephane
Experience counts
Re: [ RetroArch] [1.8.4] [ HDStation4 ] program with which you can play many emulators and games
Post by QNAP_Stephane » Thu Feb 20, 2020 1:28 am
updated
QnapClub AppCenter - https://www.qnapclub.eu
mturcotte
Post by mturcotte » Fri Feb 21, 2020 10:55 am
version 1.8.4 updated with the assets and combined with XBOXDrv 8.8.2 works with my PC Xbox USB controller.
Only problem I have now is I don't have sound, but it worked fine in 1.7.5. any clue?
Return to “Community Apps”
