[ Wake On Lan ] [ 1.01 ] Wake up any device on your LAN remotely
- QNAP_Stephane
Source : http://iptuning.net/wiki/PHP_Wake_On_Lan
Download :
https://www.qnapclub.eu/fr/qpkg/410
Note :
Launch my WebUI and modified the config.php according your LAN config and computer MacAdress
user : qnap
pass : qnap
if you need to change it , modifiy the file /opt/WakeOnLAN/wol/.htpaswd
according : http://www.htaccesstools.com/htpasswd-generator/
Last edited by QNAP_Stephane on Fri Oct 19, 2018 10:56 pm, edited 2 times in total.
- OneCD
Re: [ Wake On Lan ] [ 1.00 ] Wake up any device on your LAN remotely
Yeah. Thanks Stephane.
Great!!!
Thanks Stephane
Thanks Stephane
Thank you - Thank you Stephane !! (if you ever make a 2.0 version, I'd love to see one that ran internal to the unit (so to speak), so I wouldn't have to open up the web space on the outside. But with the help of older posts - especially one from Patrick Wilson, I was able to easily protect the wol directory with an .htaccess). I really appreciate you making and sharing this!
OneCD - Thank you for linking me here from another post and for letting me know about Patrick (very sad).
Due to firewall restricitons I only have access to admin web interface. Local web server supporting php is running on different port and i dont have acces to it from the internet. Thus this app does not work.
Is there any other solution?
UPDATE: i have also access to another port, where transmission web interface is runnnig. Is there a way to use the same port for WOL?
Hello, it's possible to run this utility with TS-251 model@QTS v4.3.3? Thanks for reply.
Hi all,
I love this app but the problem is everyone can access to my qnap with XXXX.ddns.net/wol and change anything.
There is any way to restrict access to this WebUI?
Thanks in advance
Thanks in advance
- QNAP_Stephane
Hi Stephane,QNAP_Stephane wrote:you can secure http access directory
Thanks for your reply. I´m noob whit that. Ok, I can create the htpasswd file, but I don't know where I should copy this file and I don't know how can I protect the access to the http://XXXXXXX.ddns.net/wol/
Could you please help me?
- QNAP_Stephane
need to check for update it .. will be more simple than an explanation
So, are you going to update it to restrict the access??
Wow! It would be fantastic!
this request needs to go to the developer..not stephane
- QNAP_Stephane
Re: [ Wake On Lan ] [ 1.01 ] Wake up any device on your LAN remotely
updated
with user and password request (qnap/qnap)
