[ Ombi 3 ] [ 3.0.5202 ] Want a Movie or TV Show on Plex or Emby
- QNAP_Stephane
Source : https://github.com/tidusjar/Ombi
Download :
https://qnapclub.eu/fr/qpkg/487
arm-x41 added (not compatible with TS-531P)
arm-x41 require Apache74 as dependency
About :
Here are some of the features Ombi V3 has:
Now working without crashes on Linux.
Lets users request Movies and TV Shows (whether it being the entire series, an entire season, or even single episodes.)
Easily manage your requests
User management system (supports plex.tv, Emby and local accounts)
A landing page that will give you the availability of your Plex/Emby server and also add custom notification text to inform your users of downtime.
Allows your users to get custom notifications!
Secure authentication so you don't have to worry about those script kiddies
Will show if the request is already on plex or even if it's already monitored.
Automatically updates the status of requests when they are available on Plex/Emby
Slick, responsive and mobile friendly UI
Ombi will automatically update itself
Very fast system.
Integration
We integrate with the following applications:
Plex Media Server
Emby
Sonarr
Radarr (beta)
DogNzb
Couch Potato
Notifications
Supported notifications:
SMTP Notifications (Email)
Discord
Slack
Pushbullet
Pushover
Mattermost
Last edited by QNAP_Stephane on Wed Jul 22, 2020 1:14 am, edited 30 times in total.
- peelos
- Been there, done that
Re: [ Ombi 3 ] [ 3.0.2122 ] Want a Movie or TV Show on Plex or Emby
Awesome, many thanks Stephane!
NAS: TVS-1282-i7-7700-40G / 4 x 500GB SSD 2.5" RAID 10 / 2 x 500GB M.2 SSD / 8 x 12TB WD Whites 3.5" RAID 6 / Noctua L9x65 / 3 x 80mm PWM Noctua fans / Corsair 600W PSU / Asus Turbo GTX 1060 6GB GPU
Software: Plex Media Server / Transmission / Sonarr / Radarr / Bazarr / Jackett / Tautulli / Home Assistant / Resilio Sync / Python / NetData / SortMyQPKGs
pfSense Firewall / OpenVPN Server: QOTOM Fanless Mini PC / Core i5 / 8GB RAM / 128GB SSD / 4 Gigabit NICs / AES-NI
Wireless Routers: 2 x Netgear AC1900 R7000 Nighthawk / 1 x Netgear AC3200 R8000 Nighthawk / FreshTomato Firmware
- GTunney
Anybody managed to get this to work with Couchpotato when using an SSL cert?
I just can't get it to connect using SSL. I have a genuine issue cert from comodo and not self signed.
2017-10-17 10:27:42.160 +01:00 [Information] Start installing Hangfire SQL objects...
2017-10-17 10:27:42.343 +01:00 [Information] Hangfire SQL objects installed.
2017-10-17 10:27:42.415 +01:00 [Information] Starting Hangfire Server
2017-10-17 10:27:42.424 +01:00 [Information] Using job storage: 'SQLite Server: Ombi.db'
2017-10-17 10:27:42.425 +01:00 [Information] Using the following options for Hangfire Server:
2017-10-17 10:27:42.425 +01:00 [Information] Worker count: 1
2017-10-17 10:27:42.426 +01:00 [Information] Listening queues: 'default'
2017-10-17 10:27:42.426 +01:00 [Information] Shutdown timeout: 00:00:15
2017-10-17 10:27:42.426 +01:00 [Information] Schedule polling interval: 00:00:15
2017-10-17 10:27:57.327 +01:00 [Error] Could not test CP
System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.Http.CurlException: SSL peer certificate or SSH remote key was not OK
at System.Net.Http.CurlHandler.ThrowIfCURLEError(CURLcode error)
at System.Net.Http.CurlHandler.MultiAgent.FinishRequest(StrongToWeakReference`1 easyWrapper, CURLcode messageResult)
--- End of inner exception stack trace ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult()
at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at Ombi.Api.Api.<Request>d__8`1.MoveNext() in C:\projects\requestplex\src\Ombi.Api\Api.cs:line 69
at Ombi.Api.CouchPotato.CouchPotatoApi.<Status>d__4.MoveNext() in C:\projects\requestplex\src\Ombi.Api.CouchPotato\CouchPotatoApi.cs:line 54
at Ombi.Controllers.External.TesterController.<CouchPotato>d__53.MoveNext() in C:\projects\requestplex\src\Ombi\Controllers\External\TesterController.cs:line 285
Model: TS-453D 8GB
Disks: 3 x 4TB Western Digital WD40EFRX - RAID 5
Total Storage: 7.2TB
Applications: Plex | Sonarr | QSabnzbd+ | Radarr | Home Assistant | MQTT/Z2M
Other Devices: Netgear D7000 AC1900 VDSL Router | FTTP - 1014/104 | Netgear GS108 Gigabit Switch
Fyi this is in open beta. Qnap-Stephene can you package the latest build which is 3.0.2124. Internal updater does not appear to work with our qpkg.
thanks
thanks
- nickiman
Re: [ Ombi 3 ] [ 3.0.2143 ] Want a Movie or TV Show on Plex or Emby
Someone having problems after upgrade Ombi 3 to 3.0.2143 version from the repo?
I can´t reach to the app right now (the web page doesn´t load) even from my LAN´s network or from HD Station.
EDIT: I think the problem is related with this issue opened in GitHub:
https://github.com/tidusjar/Ombi/issues/1580
TS-453 Pro - FW: QTS 5.1.4.2596
6Tb WD Red WD6002FFWX (x4) with RAID 5
just updated an no problems reaching it on my system.nickiman wrote:Someone having problems after upgrade Ombi 3 to 3.0.2143 version from the repo?
- nickiman
Ah, OK... in that case I will reinstall it, maybe I´ve made something wrong.mdhwoods wrote: just updated an no problems reaching it on my system.
i noticed if you click the update button, it eventually crashes and requires a reinstall. maybe you did that? I decided to install it as a docker so i can stay on the current build, this one is still 1 or 2 behind.nickiman wrote:Ah, OK... in that case I will reinstall it, maybe I´ve made something wrong.mdhwoods wrote: just updated an no problems reaching it on my system.
- QNAP_Stephane
Re: [ Ombi 3 ] [ 3.0.2297 ] Want a Movie or TV Show on Plex or Emby
updated
The self updater within Ombi isnt working (for me at least), any chance we can get the latest update? Thanks!
- QNAP_Stephane
Re: [ Ombi 3 ] [ 3.0.2450 ] Want a Movie or TV Show on Plex or Emby
updated
Accidentally posted in an older post about Ombi. I was having an issue that nunkistein was having with the updater not working, hope to see a new update for this soon! Thanks for your work on this! https://github.com/tidusjar/Ombi/issues ... -363220323 Here is the issue for github if anyone is interested.
- peelos
apologies for the maybe simple question but I am new to docker, how did you install the latest v3 prerelease version in docker?mdhwoods wrote:i noticed if you click the update button, it eventually crashes and requires a reinstall. maybe you did that? I decided to install it as a docker so i can stay on the current build, this one is still 1 or 2 behind.nickiman wrote:Ah, OK... in that case I will reinstall it, maybe I´ve made something wrong.mdhwoods wrote: just updated an no problems reaching it on my system.
- peelos
Re: [ Ombi 3 ] [ 3.0.2849 ] Want a Movie or TV Show on Plex or Emby
could we get the latest version please Stephane? the current file on qnapclub I again get "data file error" had to install the previous version.
