[ Restic ] [ 0.15.0 ] Fast, secure, efficient backup program [ CLI ]
- QNAP_Stephane
Source : https://restic.github.io/
manual : https://restic.readthedocs.io/en/stable/manual.html
Download : [ x64, x86, arm, arm64 ]
https://www.qnapclub.eu/fr/qpkg/496
Note :
restic command line added to NAS $PATH
About :
restic is a program that does backups right. The design goals are:
Easy: Doing backups should be a frictionless process, otherwise you are tempted to skip it. Restic should be easy to configure and use, so that in the unlikely event of a data loss you can just restore it. Likewise, restoring data should not be complicated.
Fast: Backing up your data with restic should only be limited by your network or hard disk bandwidth so that you can backup your files every day. Nobody does backups if it takes too much time. Restoring backups should only transfer data that is needed for the files that are to be restored, so that this process is also fast.
Verifiable: Much more important than backup is restore, so restic enables you to easily verify that all data can be restored.
Secure: Restic uses cryptography to guarantee confidentiality and integrity of your data. The location the backup data is stored is assumed not to be a trusted environment (e.g. a shared space where others like system administrators are able to access your backups). Restic is built to secure your data against such attackers.
Efficient: With the growth of data, additional snapshots should only take the storage of the actual increment. Even more, duplicate data should be de-duplicated before it is actually written to the storage backend to save precious backup space.
Free: restic is free software and licensed under the BSD 2-Clause License
Note :
About :
Last edited by QNAP_Stephane on Wed Jan 25, 2023 6:51 pm, edited 8 times in total.
Re: [ Restic ] [ 0.7.3 ] Fast, secure, efficient backup program [ CLI ]
Can restic be incorporated to the hybrid backup sync?
- QNAP_Stephane
no it is independant command line, just like rclone
Hey Stephane, there's a new release available. Could you please update your app?
Thanks a lot! Really appreciate your effort
- QNAP_Stephane
Re: [ Restic ] [ 0.9.1 ] Fast, secure, efficient backup program [ CLI ]
updated
- QNAP_Stephane
Re: [ Restic ] [ 0.9.2 ] Fast, secure, efficient backup program [ CLI ]
updated
Thanks Stephane!
Any chance you could also create a restic-server package?
https://github.com/restic/rest-server
- QNAP_Stephane
Thanks Seb to ping me about thisseb13 wrote:Thanks Stephane!
it is availalbe : https://www.qnapclub.eu/fr/qpkg/651
- QNAP_Stephane
Re: [ Restic ] [ 0.9.3 ] Fast, secure, efficient backup program [ CLI ]
also updated client to 0.9.3
Wow, thanks. That was quick! Just tested. Works like a charm!QNAP_Stephane wrote: it is availalbe : https://www.qnapclub.eu/fr/qpkg/651
One hint for your description: You called the share RestBackup not ResticBackup as mentioned in the details.
- QNAP_Stephane
Re: [ Restic ] [ 0.12.0 ] Fast, secure, efficient backup program [ CLI ]
updated
Any chances for an update to 12.1? Thanks
I see it's there now! Thanks!
Any chances for an update to 13.1? Thanks
- QNAP_Stephane
Re: [ Restic ] [ 0.13.1 ] Fast, secure, efficient backup program [ CLI ]
has been updated
