[ Music Player Daemon ] [ 0.20.12 ] flexible, powerful, server-side application for playing music
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
Source : https://www.musicpd.org
Download : x64, x86 (fw 4.2.6)
https://qnapclub.eu/index.php?act=detail&qpkg_id=510
Note :
due to multiple dependencies and cross compilation issue, the binaries runs under another ELF.
Start mpd daemon on start (no UI)
Config file to edit and adapt to your need in /opt/MPD/etc/mpd.conf (restart qpkg to make change take effect)
About :
Music Player Daemon (MPD) is a flexible, powerful, server-side application for playing music. Through plugins and libraries it can play a variety of sound files while being controlled by its network protocol.
QNAP_Stephane
Experience counts
Re: [ Music Player Daemon ] [ 0.20.12 ] flexible, powerful, server-side application for playing music
x86 version added
Austin10
First post
Post by Austin10 »
i have a QNAP TS-453Be - mpd runs but audio comes out of the built in speaker, I would like it to come out of HDMI so that I can send it to my receiver.
via telnet and command line, issuing this command: aplay -D hdmi:CARD=Intel,DEV=0 /opt/test.wav
i get sound via HDMI output (which is what I want).
Also with: aplay -D hw:0,3 works. but none of these work with mpd.conf in the audio_output for device. I get: Failed to open Alsa device 'default' no such file or directory.
audio_output{
type "alsa"
name "default"
device "hw:0,3"
In mpd.conf device hw:0,0 does not work either, same error: Failed to open Alsa device 'default' no such file or directory.
Commenting out the whole section directs output to the integrated speaker.
I do not have HybridDeskStation installed (shouldn't need to). There is no pulse audio on this. I have tried setting defaults via asound.conf, and alsa.conf and . asoundrc mpd totally ignores them all. Alsa - D obeys them all. Where is MPD getting its "default" output device config from??
Any help or insight would be appreciated to get this running out the desired output!
fabianka
First post
Post by fabianka »
is there a chance for an updated build?
Bloob
Post by Bloob »
Yeah, it'd be really nice to have access to the partitions feature that comes with 0.22.
Return to “Community Apps”
