[ QMariaDB ] [ 10.5.11 ] MariaDB Server (wth PhPMyadmin)
- QNAP_Stephane
Source : https://mariadb.com
Download : x64 version, arm64
https://qnapclub.eu/fr/qpkg/525
Note :
-[ QPKG Integration ]-
all DB are stored in a share called QMariaDB create on first launch
Listen on port 3308 to not interact with embedded MariaDB
Socket under /tmp/QMariadDB2.sock
root password on start set as qnap (change it over the phpmyadmin embbeded)
About :
MariaDB creates open source database solutions to fulfill today's needs and tomorrow's possibilities by combining engineering leadership and community innovation on a global scale — and without sacrificing SQL or the performance, reliability and security you've come to expect.
Last edited by QNAP_Stephane on Sun Jul 04, 2021 12:43 am, edited 6 times in total.
Re: [ QMariaDB ] [ 10.2.12 ] MariaDB Server (wth PhPMyadmin)
Hi QNAP_Stephane,
I can't access the database using PhpMyAdmin.
#2002 - Connection refused — The server is not responding (or the local server's socket is not correctly configured).
mysqli_real_connect(): (HY000/2002): Connection refused
Is there any setup needed?
oh wait. Does this install replace the current Qnap MariaDb v5? I dont know what happened but It caused caos on my NAS.
I had to uninstall.
Cheers
I had to uninstall.
Cheers
- Toxic17
this sometimes this happens with Cookies in phpMyAdmin. have you tried clearing the Browsers Cache?
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
- QNAP_Stephane
Use the embedded phpmyadmin inside qmariadb preset to listen on 3308
Envoyé de mon SM-G925F en utilisant Tapatalk
I have reinstalled and cleared the browser cache but the issue persist.
I can see the process running.
Also QmariaDb v10 seems to be replacing Qnap MariaDB v5.
Control panel > SQL Server - QMariaDB v10.2.12
This is an issue because I have dbs in v5.
- QNAP_Stephane
I will double check
- QNAP_Stephane
OH think i think found Why....
by hazard they are sharing the same pid... i will change this in 10.2.12.1
- QNAP_Stephane
published 10.2.12.1
tested PHPMyAdmin standard log well on the 5.5.57-MariaDB
tested PHPMy Admin (embbeded to QMariaDB2) log well on the 10.2.12-MariaDB-log
i just modified the pid location&name and also socket.. but i have no clue why QTS interface still display 10.2.12.1...
sorry but still the same issues.
- Trexx
Still seeing same interaction issues with QTS SQL Interface. Also seems to affect installation of QTS SQL if active during upgrade to 4.3.5beta. Removed QMariaDB, but QTS Sql was shown as uninstalled. Even post reboot after removal. Had to reinstall 4.3.5 beta2 firmware to fix.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- QNAP_Stephane
think i have still some improvment to bring to isolate this qpkg from the whole QTS and not impact the behaviors of the OS
Unfortunately I am facing the same issues as Trexx. Is there any update?
Hi QNAP_Stephane,
was there any improvement in this? Is it safe to use?
I need to run updated mariadb and the qnap db is v5.5 outdated.
Last attempt I did with QMariaDB I was forced to reset firmware. Could you confirm it's ok now.
Cheers
Cheers
Last edited by presenceofmind on Fri Jul 26, 2019 4:13 am, edited 1 time in total.
Hi QNAP_Stephane,
I'm still unable to log on the server.
" #2002 - Connection refused — The server is not responding (or the local server's socket is not correctly configured)."
What do I have to do to get this going?
I tried installing another phpadmin (qnap store) and it returns
"Login without a password is forbidden by configuration (see AllowNoPassword)"
Please could you have a look? I really need updated mariadb running on my server.
Cheers
Cheers
