[ Tautulli ] [ 2.11.1.0 ] Monitoring and tracking tool for Plex Media Server (ex PlexPy )
- QNAP_Stephane
Source : http://tautulli.com
Download :
https://www.myqnap.org/product/tautulli/
about :
web application for monitoring, analytics and notifications for Plex Media Server.
Features
Responsive web design viewable on desktop, tablet and mobile web browsers.
Themed to complement Plex/Web.
Easy configuration setup (no separate web server required).
Monitor current Plex Media Server activity.
Fully customizable notifications for stream activity and recently added media.
Top statistics on home page with configurable duration and measurement metric.
Global watching history with search/filtering & dynamic column sorting.
Full user list with general information and comparison stats.
Individual user information including devices IP addresses.
Complete library statistics and media file information.
Rich analytics presented using Highcharts graphing.
Beautiful content information pages.
Full sync list data on all users syncing items from your library.
And many more!!
Last edited by QNAP_Stephane on Fri Dec 23, 2022 3:55 pm, edited 18 times in total.
- QNAP_Stephane
Re: [ Tautulli ] [ 2.0.22 ] Monitoring and tracking tool for Plex Media Server (ex PlexPy )
arm-x41 + arm64 version added
- jameshenderson
Does anyone know of a way to import the old PlexPy history etc?
thanks,
James.
thanks,
James.
TS-453Bmini + 4x 4TB Western Digital Reds (RAID5) - Plex Media Server
I can't install the package on my TS-253A running Firmware 4.3.4.
Error Tautulli 2.0.22 installation failed. Data file error.
Anyone a solution?
Thanks!
Anyone a solution?
Thanks!
I can update from Plexpy package and it is ok, all db and data is funtionally.
But i want to try Tautulli Remote Android App Notification but in Settings says:
The PyCryptodome library is missing. The content of your notifications will be sent unencrypted!
Please install the library to encrypt the notification contents. Instructions can be found in the FAQ.
Someone has been able to install the necessary PyCryptodome library package to make it work?
- peelos
- Been there, done that
Updated from plexpy and and Android remote working fine on my side.. can you perhaps backup the database and reinstall?deejayexe wrote:I can update from Plexpy package and it is ok, all db and data is funtionally.
NAS: TVS-1282-i7-7700-40G / 4 x 500GB SSD 2.5" RAID 10 / 2 x 500GB M.2 SSD / 8 x 12TB WD Whites 3.5" RAID 6 / Noctua L9x65 / 3 x 80mm PWM Noctua fans / Corsair 600W PSU / Asus Turbo GTX 1060 6GB GPU
Software: Plex Media Server / Transmission / Sonarr / Radarr / Bazarr / Jackett / Tautulli / Home Assistant / Resilio Sync / Python / NetData / SortMyQPKGs
pfSense Firewall / OpenVPN Server: QOTOM Fanless Mini PC / Core i5 / 8GB RAM / 128GB SSD / 4 Gigabit NICs / AES-NI
Wireless Routers: 2 x Netgear AC1900 R7000 Nighthawk / 1 x Netgear AC3200 R8000 Nighthawk / FreshTomato Firmware
- peelos
You should be able to use the backup file from plexpy or upgrade from there..jameshenderson wrote:Does anyone know of a way to import the old PlexPy history etc?
thanks,
James.
This may help otherwise: https://github.com/Tautulli/Tautulli-Wiki
My question is still do we even need the new Tautulli .qpkg if we can update from within the plexpy .qpkg and avoid having to restore history etc
I updated and I lost the ability to set notifications ....
QNAP TS-1677X 1700 RAM 64G
download/file.php?mode=view&id=24574peelos wrote:Updated from plexpy and and Android remote working fine on my side.. can you perhaps backup the database and reinstall?deejayexe wrote:I can update from Plexpy package and it is ok, all db and data is funtionally.
Hi!
I say about tautulli notification agent that i dont know i can install PyCryptodome library for phyton for i receive notification in my tautulli app in android.
- peelos
Notifications work fine, the message advises that you need PyCryptodome for encrypted messagesdeejayexe wrote:download/file.php?mode=view&id=24574peelos wrote:Updated from plexpy and and Android remote working fine on my side.. can you perhaps backup the database and reinstall?deejayexe wrote:I can update from Plexpy package and it is ok, all db and data is funtionally.
Hi!
- jameshenderson
Hi All,
I updated PlexPy to Tautulli "in app" but have been unable to update from 2.0.22 to 2.0.25.
The advice I got from Tautulli on GitHub https://github.com/Tautulli/Tautulli-Is ... -376610979 was to install the Tautulli .qpkg and copy across the Tautulli.db (when both were shutdown).
Does anyone know how to access Tautulli.db as it is in the .qpkg directory which I can neither see nor access.
thanks!
James.
[edit: typos]
thanks!
James.
[edit: typos]
Last edited by jameshenderson on Wed Mar 28, 2018 5:09 pm, edited 1 time in total.
- jameshenderson
OK, well I have worked this out if anyone is interested. It can only be done through terminal commands.jameshenderson wrote:Does anyone know how to access Tautulli.db as it is in the .qpkg directory which I can neither see nor access.
My tautulli.db was here:
/share/CACHEDEV1_DATA/.qpkg/Tautulli/DATADIR/tautulli.db
So now, I am using the (new) Tautulli .qpkg (thanks to QNAP_Stephanie) and it immediately updated itself to v2.0.25
Anyone heard of an update for this? I believe version v2.1.9 is the latest. TIA!
- QNAP_Stephane
Re: [ Tautulli ] [ 2.1.9 ] Monitoring and tracking tool for Plex Media Server (ex PlexPy )
updated
anybody using SSL with it? how to enable?
