[ AdGuard Home ] [ 0.107.24 ] Network-wide ads & trackers blocking DNS server
- QNAP_Stephane
Source : https://adguard.com/ https://github.com/AdguardTeam/AdGuardHome
Download : x64, x86, arm-x41 , arm-x31
Premium
https://www.myqnap.org/product/adguardhome-premium/
Start on all NAS please read information on myqnap.org
Legacy
https://www.myqnap.org/product/adguard-home/
About :
Privacy protection center for you and your devices
Free and open source, powerful network-wide ads & trackers blocking DNS server.
AdGuard Home
AdGuard Home is a network-wide software for blocking ads & tracking. After you set it up, it'll cover ALL your home devices, and you don't need any client-side software for that.
How does AdGuard Home work?
AdGuard Home operates as a DNS server that re-routes tracking domains to a "black hole," thus preventing your devices from connecting to those servers. It's based on software we use for our public AdGuard DNS servers -- both share a lot of common code.
How is this different from public AdGuard DNS servers?
Running your own AdGuard Home server allows you to do much more than using a public DNS server.
Choose what exactly will the server block or not block;
Monitor your network activity;
Add your own custom filtering rules;
In the future, AdGuard Home is supposed to become more than just a DNS server.
Last edited by QNAP_Stephane on Mon Feb 27, 2023 3:51 pm, edited 14 times in total.
- Skeptical.me
- Easy as a breeze
Re: [ AdGuard Home ] [ 0.9.0.1 ] Network-wide ads & trackers blocking DNS server
"Router
This setup will automatically cover all the devices connected to your home router, and you will not need to configure each of them manually.
Open the preferences for your router. Usually, you can access it from your browser via a URL (like http://192.168.0.1/ or http://192.168.1.1/). You may be asked to enter the password. If you don’t remember it, you can often reset the password by pressing a button on the router itself. Some routers require a specific application, which in that case should be already installed on your computer/phone.
Find the DHCP/DNS settings. Look for the ’DNS’ letters next to a field which allows two or three sets of numbers, each broken into four groups of one to three digits.
Enter your AdGuard Home server addresses there."
I'm using a QNAP TS-253Be and I've installed the .qpkg that was created for QNAP models and have put 192.168.1.219 (NAS IP) into the DHCP>DNS field (which is what you have to if using your router) and my devices are still showing ads. Also, no devices show in AdGuard Home https://imgur.com/a/xScvcDv
https://github.com/AdguardTeam/AdGuardHome/wiki
If anyone can successfully set this up in their router/ NAS it would be great if you could detial what edits to the router/NAS you made to get it working. Thanks
QNAP TS-253Be 2 x WD Red 6TB RAID1, & 1 x WD Ext. 6TB, QTS: 4.5.3.1670
Plex, Radar, Sonarr, Lidarr, NZBGet, NZBHydra 2, Container Station
- QNAP_Stephane
arm64 version added
Can you help us regarding port 16553QNAP_Stephane wrote:arm64 version added
When we enter DNS in router it suppose to only listen on 53
How to configure router/qnap for the changed dns port?
- QNAP_Stephane
for coredns port
simply edit /opt/AdGuard/AdGuardHome.yaml to fit on your needs...
and restart
but dont think using :53 will work (cant say for the NAS itself.. but probably somwhere in dnsmasq config )
and restart
Thanks for reply, but if we can't use port 53, what our other options? What the purpose of change the default 16553??QNAP_Stephane wrote:for coredns port
and restart
I think we only have little options:
- Configure Adguard app to use another IP other than server IP.
- Add a rule in router to forward "port 53" queries to "16553" << I don't know how exactly.
So how you managed to make it work in your system?
I think I like Adguard UI better than pi hole, but I have the same problem with pi-hole regarding port 53 (Was working fine in older firmware)
Look to this topic:
viewtopic.php?t=143406
Specifically:
I tried that, but it give me error in command:NOTES
I do not know if this was ultimately necessary, but I did manually kill the dnsmasq process running on the QNAP. I was getting a message from the container saying that port 53 was already being used. From the command line, issue a "ps x | grep dnsmasq" command. Then take the process number and issue a "sudo kill X" where X is the process number. You can reissue the "ps x | grep dnsmasq" to make sure dnsmasq is no longer running.
Top
*USER* is not in the sudoers file. This incident will be reported.
I disabled admin account by the way, and logged through a new Adminstrator account (myusername)
- QNAP_Stephane
ok think i have found a work around
stop adguard
AdGuardHome.yaml and modify to
edit /etc/dnsmasq.conf
and change port 53 to 1053 (for example)
edit /etc/resolv.conf and modify
in ssh restart dnsmask
restart adguard.. it is running now on port 53
not sure it will be reboot persistent (i opened a ticket on Qnap bugtracker to make R&D change the binding and ports)
stop adguard
coredns:
port: 53
protection_enabled: true
nameserver 127.0.1.1:1053
killall -9 dnsmasq # kill dnsmasq process
dnsmasq # restart dnsmasq
Thanks, it finally work!QNAP_Stephane wrote:ok think i have found a work around
stop adguard
Many thanks @QNAP_Stephane !
This one is working nicely and cover all device very easily (after the small tweak)...
Regards,
Regards,
TVS-863 owner
- Skeptical.me
- Easy as a breeze
stop adguard
edit /etc/dnsmasq.confCode: Select all
coredns: port: 53 protection_enabled: true
in ssh restart dnsmaskCode: Select all
restart adguard.. it is running now on port 53Code: Select all
killall -9 dnsmasq # kill dnsmasq process dnsmasq # restart dnsmasq
Sorry for the noob question Stephane, or ayone else. How do I find the .yaml file in SSH terminal?
Go to "/share/CACHEDEV1_DATA/.qpkg/AdGuard "
TVS-863 owner
- Skeptical.me
- Easy as a breeze
Oh, of course. thank you very much, I forget these things so easily.Flyingfufu wrote:Go to "/share/CACHEDEV1_DATA/.qpkg/AdGuard "
- QNAP_Stephane
or by symlink set in /opt
/opt/AdGuard
/opt/AdGuard
- Skeptical.me
- Easy as a breeze
QNAP_Stephane wrote:or by symlink set in /opt
/opt/AdGuard
Thanks Stephane.
Request:QNAP_Stephane wrote: ↑Sat Oct 20, 2018 1:28 am In the future, AdGuard Home is supposed to become more than just a DNS server.
I port-forwarded my NAS to be visible from outside, I'm sucessefully used my external IP as dns server (not static ip from my isp by the way).
- Since Android 9 support system wide dns server (regardless of connection on WiFi or cellular network) but only support it over tls, so I failed to add my NAS domain name (or even external IP).
Can you help in this matter?
Thanks.
