[ Apache73 ][2454.73330] Apache WebServer with PHP 7.3 and PECL extensions
- QNAP_Stephane
Source : https://httpd.apache.org/ / https://www.php.net / https://pecl.php.net
Download :
https://www.myqnap.org/product/apache73/
Changelog :
2439.7304 https://www.qnapclub.eu/fr/qpkg/releasenotes/735
About :
Complete Apache HTTP Web Server with PHP 7.3.x branch
and more 20 PECL php extension embedded,
Generate and update ca-certificates automatically on your NAS
Composer embedded and added to NAS $PATH command line
with basic web admin allowing to modify httpd.conf, httpd-SSL.conf, php.ini ...
Run aside the embedded Qnap Webserver on port 2288 by default.
Listen Web page inside htdocs share (created automatically on first install)
Download :
Changelog :
About :
Last edited by QNAP_Stephane on Thu Nov 03, 2022 10:54 pm, edited 33 times in total.
Re: [ Apache73 ] [2439.7304] Apache WebServer with PHP 7.3 and PECL extensions
Can I upgrade my currently installed qapache with qapache73 or will it install a new apache server?
- QNAP_Stephane
it will run aside, but sharing the same htdocs
- Toxic17
Excellent. I was thinking the same idea, since I am guessing some php/html scripting on my Website may use deprecated values. At least I can test the new 7.3 aside 7.2
Regards Simon
Qnap Downloads
MyQNap.Org Repository
NAS: TS-673A QuTS hero h5.1.6.25734 • TS-121 4.3.3.2420 • APC Back-UPS ES 850G2
Network: VM Hub3: 500/50 • UniFi UDM Pro: 3.2.12 • UniFi Network Controller: 8.1.127
USW-Aggregation: 7.0.50 • US-16-150W: 7.0.50 • US-8-60W: 7.0.50 • 2x USW Mini Flex 2.0.0 • UniFi AC Pro 6.6.69 • UniFi U6-LR 6.6.69
UniFi Protect: 3.0.26/8TB Skyhawk AI • 3x G3 Instants: 4.70.39 • UniFi G3 Flex: 4.70.39 • UniFi G5 Flex: 4.70.39
Qnap Downloads
- Toxic17
Stephanie. I noticed that phpMyAdmin and other web based SQL apps were not connecting correctky.
The issue appears to be the the localhost name in the web based apps. I ended up fixing this by using 127.0.0.1 instead of the "localhost" name.
Is there somewhere in the Apache/php setting where it's is set?
Sent from my ONEPLUS A6003 using Tapatalk
Regards Simon
Qnap Downloads
Qnap Downloads
- QNAP_Stephane
Hi Simon,
this behavior always been, even with Qapache
if i remember it s a mysql config file to modify
- Toxic17
ok no worries. I only noticed this issue since moving to 7.3, not a real issue as such since a fix is in place for it.
Regards Simon
Qnap Downloads
Qnap Downloads
- QNAP_Stephane
ARM64 version added
- QNAP_Stephane
Re: [ Apache73 ] [2439.7305] Apache WebServer with PHP 7.3 and PECL extensions
php core update to 7.3.5
- Toxic17
Hi Stephane.
I installed this new update via SSH by backing up my config files etc, removing the old Apache 7.3.4 and then installing a new version however when I used the commandline:
sh Apache73_2439.7305_x86_64.qpkg
I got the following error at the bottom of the installation script output.
All settings correct for using Composer
Downloading...
Composer (version 1.8.5) successfully installed to: /share/CACHEDEV1_DATA/.qpkg/Apache73/bin/composer
Use it: php /opt/Apache73/bin/composer
[/share/Public] # shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
[/share/Public] # sh Apache73_2439.7305_x86_64.qpkg
Install QNAP package on TS-NAS...
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
21867+1 records in
21867+1 records out
538822645 bytes (513.9MB) copied, 2.937701 seconds, 174.9MB/s
526193+1 records in
526193+1 records out
538822645 bytes (513.9MB) copied, 2.938645 seconds, 174.9MB/s
Firmware check is fine.
Link service start/stop script: Apache73.sh
Set QPKG information in /etc/config/qpkg.conf
seems to be first install, prepare config
/usr/bin/perl exists
/etc/ssl/ca-bundle.crt exists
share htdocs exists in your share
file index.html exists in your share htdocs
file test.php exists in your share htdocs
directory htdocs/cgi-bin exists in your share
Apache admin exists in htdocs
Generating a RSA private key
writing new private key to '/share/CACHEDEV1_DATA/.qpkg/Apache73/etc/server.key'
Downloading...
Regards Simon
Qnap Downloads
Qnap Downloads
- Toxic17
OK I have updated and the other issue I see is the following:
php shows 7.3.4 version and not 7.3.5 when running phpinfo file on my web-server. I also loaded myPhpAdmin and this also reports PHP as 7.3.4, yet I uninstalled the old Apache 7.3.4 and then installed Apache73_2439.7305_x86_64.qpkg
/share/CACHEDEV1_DATA/.qpkg/Apache73/bin/php -v
PHP 7.3.5 (cli) (built: May 3 2019 17:29:06) ( ZTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.5, Copyright (c) 1998-2018 Zend Technologies
with Xdebug v2.7.1, Copyright (c) 2002-2019, by Derick Rethans
Regards Simon
Qnap Downloads
Qnap Downloads
- QNAP_Stephane
mmmm seems my tweak not working on upgrade i need review this...
rename /opt/Apache73/etc to /opt/Apache73/etc_old
rename /opt/Apache73/etc_ori to /opt/Apache73/etc
and restart qpkg
I will remove this in next update
and restart qpkg
Ist it possible to install the nextcloud qpkg with this apache73?
- QNAP_Stephane
simply unpack Nextcloud.tar.gz inside htdocs share (download it from nextcloud website)
and call http://ipofnas:2288/nextcloud
nextcloud should the directory name inside htdocs
