[ VaultWarden ] [ 1.28.0.0 ] Password management solution for individuals, teams, and business organizations.
- QNAP_Stephane
Source : https://github.com/dani-garcia/bitwarden_rs/
Download : x86_64, arm64, arm-x41
https://www.myqnap.org/product/vaultwarden/
Note :
Based on BitWarden_rs
use port 8000
disable all ADBlock on webrowser (or create rules)
prefix install : /opt/Bitwarden
Dependency : None
About :
Solve your password management problems
The easiest and safest way for individuals, teams, and business organizations to store, share, and sync sensitive data
YOUR ONLINE SAFETY IS AT RISK
Password theft is a serious problem. The websites and apps that you use are under attack every day. Security breaches occur and your passwords are stolen. When you reuse the same passwords everywhere hackers can easily access your email, bank, and other important accounts.
HOW DO YOU STAY SAFE?
Security experts recommend that you use a different, randomly generated password for every online account that you create. But how are you supposed to remember and keep up with that many passwords? Bitwarden helps you create and manage secure passwords so that you can get back to enjoying your life online.
[b]BUY IT NOW[/b]
Your gratitude and finance will help me to continue integration of this QPKG and maintain up to date versions.
Greetings to
dani-garcia : https://github.com/dani-garcia/bitwarden_rs/
Last edited by QNAP_Stephane on Wed Mar 29, 2023 4:54 pm, edited 26 times in total.
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.9.1 ] Password management solution for individuals, teams, and business organizations.
updated
Web Vault updated to 2.10.1
bug fix :
Fixed broken U2F in Chrome 74+
Added images to email
Updated dependencies
- QNAP_Stephane
arm-x41 version added
Hello Stephane
Before I start, thank you for your work on all the QNAP extensions!!!
Currently a big fan of Qapache and now not far away from trying Bitwarden.
On which Bitwarden server version is your QPKG based on?
Is there a possibility to test the install and then buy?
I have a QNAP TVS-671 with 16GB of RAM and QTS 4.3.6.0993 build 20190704
Then I have a few questions about how the QPKG is working:
- Is this a QPKG with integrated Docker or did you rebuild everything so that we have just the package?
- Which database is it using, I hope the internal MariaDB?
- Can I use my Lets Encrypt cert from my QNAP name?
- Can I use the Mobile and Desktop App?
I know those are a lot of questions, but before I install something I want to know what comes onto my system.
Thank you,
Alain
Thank you,
Alain
- QNAP_Stephane
Hi Alain
can you please contact me directly on this forum please
https://www.forum-nas.fr/viewtopic.php? ... den#p77178
it is undockerised version, build against Rust... i am currently using sqlite as DB (for mysql/mariadb it require another version been compiled)
you can use letsencrypt and Caddy as well... I think mobile and desktop app are working as well...
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.10.0 ] Password management solution for individuals, teams, and business organizations.
updated
arm-x41 removed (buggy on latest compilation)
MySQL version is built... but a bit complicated to make a key hand package
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.11.0 ] Password management solution for individuals, teams, and business organizations.
updated
Added new icon blacklisting option, to block all non global IPs (ICON_BLACKLIST_NON_GLOBAL_IPS)
Added SQLite binary in the SQLite images, to enable backup option
Admin page scripts are loaded locally instead of using a CDN
Added CORS support
Added docker healthcheck
Added email 2FA
Updated web vault to 2.12.0
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.12.0 ] Password management solution for individuals, teams, and business organizations.
updated
Improved error message when HIBP key is not set, include a link to the page.
Added check for both the previous and next timeslots in TOTP, which is more forgiving of time mismatches (1.5 minutes now vs 30 seconds before), can be disabled setting AUTHENTICATOR_DISABLE_TIME_DRIFT=true.
Made the domain icon blacklist be cached, improving performance.
Recovery codes are now generated when adding email and Duo 2FA.
Removed MySQL libraries from SQLite images.
Added configurable SMTP timeout, and reduced the default to 15 seconds.
Updated images to be able to be built with Podman.
Added option to allow signups from specific domains only (SIGNUPS_DOMAINS_WHITELIST=domain.com,example.org).
Updated web vault to fix twofactorauth.org integration.
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.13.0 ] Password management solution for individuals, teams, and business organizations.
updated
to change ports that Bitwarden listens on and to enable SSL, edit the BitWarden.sh (open command prompt>vi)
(i added it after apache line) add the line ROCKET_PORT= and enter your desired port number
to enable SSL, add the line ROCKET_TLS= the syntax is {certs="/path/to/certs", key="/path/to/key"}
***Make sure you EXPORT the function as well... if you look a few lines under, you will see the syntax
I'm not sure if this will survive an upgrade, but this is how I was able to enable SSL, change listening port and get my instance working again.
Hope this helps
Hope this helps
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.13.1 ] Password management solution for individuals, teams, and business organizations.
updated
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.14.0 ] Password management solution for individuals, teams, and business organizations.
updated
Added support for running on subpath, simply add the subpath to the DOMAIN variable: DOMAIN=https://example.com/custom-path
Attachment size limits, per-user and per-organization, set USER_ATTACHMENT_LIMIT or ORG_ATTACHMENT_LIMIT to a value in kilobytes to apply it.
Updated U2F library which might solve some U2F certificate errors.
Added SMTP test button in the admin page.
Use web vault built by docker autobuild, using the hash to reference the image for extra security
Now accepting y/n, True/False, 1/0 as config options that are booleans.
Fixed error Unique constraint violation when using Two Factor and Postgres.
Fixed error with can_signup_user that didn't allow to change the email address.
Don't error if admin token is empty but disabled
Now email domains are converted to punycode before sending
Enable icons to be cached in the clients
Added option to change invitation org name
Enabled the sending of invitations from the admin panel, even when disabled
Dependency updates
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.14.1 ] Password management solution for individuals, teams, and business organizations.
updated
Hi
I purchased the QPKG, but I can't install it (X86_64 incompatible package).
I own a TS-259 Pro+ with QTS 4.2.6
Doesn't this work with my NAS or should I do something different?
- QNAP_Stephane
Re: [ BitWarden_rs ] [ 1.14.2 ] Password management solution for individuals, teams, and business organizations.
updated
