[ QMultimedia ] [ 1.220909 ] Set of Multimedia CLI tools
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
Source :
Download :
https://www.myqnap.org/product/qmultimedia/
About :
Set of CLI tools to manage your Mulitmedia things, used as well as dependency for some incoming QPKG
this QPKG is embedding
FFMPEG 4.4.0 (/opt/QMultimedia/bin/ffmpeg or /opt/QMultimedia/FFMPEG4.4/bin/ffmpeg)
FFMPEG 4.3.0 ( /opt/QMultimedia/FFMPEG4.3/bin/ffmpeg)
FFMPEG 4.2.5 ( /opt/QMultimedia/FFMPEG4.2/bin/ffmpeg)
FFMPEG 3.3.9 (/opt/QMultimedia/FFMPEG3.3/bin/ffmpeg)
FFMPEG 3.4.7 (/opt/QMultimedia/FFMPEG3.4/bin/ffmpeg)
all built with maximum depedencies, and all hardware acceleration engine (vaapi, drm, cuda, quicksync....) all under GPL3 + Licence
also VLC 3.0.8 Headless built (/opt/QMultimedia/VLC ) --- Beta
a recent Imagemagick 7.0 release (/opt/QMultimedia/IMAGEMAGICK)
If you want use hw transcoding function over VAAPI please set in you rapplication to use /opt/QMultimedia/bin/ffmpeg and do not forget to export :
export LIBVA_DRIVERS_PATH=/opt/QMultimedia/lib
export LIBVA_DRIVER_NAME=iHD
or
export LIBVA_DRIVER_NAME=i965
Last edited by QNAP_Stephane on Sat Oct 29, 2022 5:59 pm, edited 5 times in total.
QNAP_Stephane
Experience counts
Re: [ QMultimedia ] [ 1.200115 ] Set of Multimedia CLI tools
updated... fix missing libs for AMD series
morphts873
Post by morphts873 »
First off, THANK YOU! I love this qpkg. I can´t tell you how much I scrapped my head to get ffmpeg with cuda support on the qnap. I´m still not able to use it though.
I am trying to get this to work for weeks now. Here is a reddit link of a post that I created: Here
In short: I am trying to batch convert thousands of files using the GPU I bought (MSI GTX1050TI, compatible with my TS-873 according to Compatibility List from Qnap). But I can´t get it to run natively, in Linux Station or in Container Station. Your qpkg is getting me so close to my goal.
But I get this error at start:
[AVHWDeviceContext @ 0x157d140] Cannot load libcuda.so.1
[AVHWDeviceContext @ 0x157d140] Could not dynamically load CUDA
[hevc_cuvid @ 0x157cbc0] Error creating a CUDA device
cuvid hwaccel requested for input stream #0:0, but cannot be initialized.
[hevc_cuvid @ 0x157cbc0] ff_get_format failed: -1
Stream mapping:
Stream #0:0 -> #0:0 (hevc (hevc_cuvid) -> hevc (hevc_nvenc))
Stream #0:1 -> #0:1 (copy)
Drivers from App Center are installed.
Here is a list of all locations where libcuda.so.1 is located.
[/usr/lib] # ldconfig -p | grep cuda
libcuda.so.1 (libc6,x86-64) => /usr/local/lib/libcuda.so.1
/usr/lib] # find / | grep "libcuda.so.1"
/share/CACHEDEV1_DATA/.qpkg/NVIDIA_GPU_DRV/usr/nvidia.u18.04/libcuda.so.1
/share/CACHEDEV1_DATA/.qpkg/NVIDIA_GPU_DRV/usr/nvidia/libcuda.so.1
/share/CACHEDEV1_DATA/.qpkg/NVIDIA_GPU_DRV/usr/lib/libcuda.so.1
/share/CACHEDEV1_DATA/.qpkg/QMultimedia/FFMPEG4.2/lib/libcuda.so.1
/share/CACHEDEV1_DATA/.qpkg/QMultimedia/lib/libcuda.so.1
/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/9fe1f356effde739ca6f976ddcebb78648cf5d74aea4536be2d281c33f4f41ba/diff/usr/local/cuda-10.1/compat/libcuda.so.1
/share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/overlay2/59b4b1017dcada9375c9d88a64a8719afbc872ddf570ed1201f7f44c89e00370/diff/usr/local/cuda-10.0/compat/libcuda.so.1
QNAP_Stephane
Experience counts
cannot test, i dont have NVidia GPU here...
i guess i must cross compiled The CUDA Toolkit to include it...
but if i remember --enable-cuda option in ffpmeg is a non-free flag and cannot be distributed, i can only compil with GPL 3 dependencies
i need to double check, here just nvec headers are embedded
morphts873
Thank you for your answer.
Now I understood it a bit more how this works. Well, I am not that Linux savvy that I could do it myself, so I guess I am stuck for now without this functions.
Regrads,
morph
breschi
Post by breschi »
Hi, I buyed the package but when I tried to install it I received this error:
"Failed to install Mutlimedia Tools. QTS detected an unauthorized change in the app."
I tried also to download the QPKG but the result is the same.
QNAP_Stephane
Experience counts
Re: [ QMultimedia ] [ 1.200625 ] Set of Multimedia CLI tools
updated
FFMPEG 4.2.2 updated to 4.2.5
FFMPEG 4.3.0 added (default engine)
crazyf
Post by crazyf »
Does the app have arm version?
QNAP_Stephane
Experience counts
no only Intel
crazyf
Post by crazyf »
QNAP_Stephane wrote: Fri Jul 24, 2020 8:03 pm no only Intel
hwaccel
First post
Post by hwaccel »
Any idea how to make this work with https://github.com/mdhiggins/sickbeard_mp4_automator ?
I've tried setting its ffmpeg path to use this and it errors out.
nickiman
Know my way around
Post by nickiman »
Yesterday I was trying to install this QPKG after get it in QNAP Club but I have this erro when I try to install it:
Error	2021-03-22	22:42:53	admin	192.168.10.20	App Center	App Installation	[App Center] Failed to download Mutlimedia Tools from "https://www.qnapclub.eu/api/qpkg/model/download/470554/QMultimedia_1.200625_x86_64.qpkg?api_token=[b]HereAppearsMyAPI[/b]".
In the Purchase History appears as correctly purchased.... Do you have any idea of what´s going on?
TS-453 Pro - FW: QTS 5.1.4.2596
6Tb WD Red WD6002FFWX (x4) with RAID 5
QNAP_Stephane
Experience counts
yesterday there was some attack on Repo...
try again or download manually the qpkg
nickiman
Know my way around
Post by nickiman »
QNAP_Stephane wrote: Tue Mar 23, 2021 8:00 pm try again or download manually the qpkg
OK... now seems to be working and has been downloaded from the repo successfully.
QNAP_Stephane wrote: Tue Mar 23, 2021 8:00 pm yesterday there was some attack on Repo...
Ummm this makes me worried
I´ve wake up this morning with a lot of notifications regarding failed login attempts from several IPs during all night long.... Could be related with that attacks to the Repo?
QNAP_Stephane
Experience counts
nothin related with qnapclub
change your 8080 QTS port to custom ones, also SSH por
Return to “Community Apps”
