Source :https://github.com/dani-garcia/bitwarden_rs/
Download :
https://www.qnapclub.eu/fr/qpkg/880
[ QPKG Integration] - Based on BitWarden_rs
MariadDB embedded running on port 23309
use port 8000 HTTP
disable all ADBlock on webrowser (or create rules)
prefix install : /opt/Bitwarden
for HTTPS unset in startup file (for LetsEncrypt for myqnapcloud) and HTTPS will go over port 8000
export ROCKET_TLS='{certs="/mnt/ext/opt/QcloudSSLCertificate/cert/cert",key="/mnt/ext/opt/QcloudSSLCertificate/cert/key"}'
Password management solution for individuals, teams, and business organizations.Note: building the Vault needs ~1.5GB of RAM. On systems like a RaspberryPI with 1GB or less, please enable swapping or build it on a more powerful machine and copy the directory from there. This much memory is only needed for building it, running bitwarden_rs with vault needs only about 10MB of RAM
Solve your password management problems
The easiest and safest way for individuals, teams, and business organizations to store, share, and sync sensitive data
YOUR ONLINE SAFETY IS AT RISK
Password theft is a serious problem. The websites and apps that you use are under attack every day. Security breaches occur and your passwords are stolen. When you reuse the same passwords everywhere hackers can easily access your email, bank, and other important accounts.
HOW DO YOU STAY SAFE?
Security experts recommend that you use a different, randomly generated password for every online account that you create. But how are you supposed to remember and keep up with that many passwords? Bitwarden helps you create and manage secure passwords so that you can get back to enjoying your life online.
