[ Lidarr .NET ] [ 1.1.1.2762 ] Looks and smells like Sonarr but made for music (Dot Net version)
- QNAP_Stephane
Source : http://lidarr.audio
Download : x64 , arm64
Apache80: https://www.myqnap.org/product/lidarr80/
Apache81 : https://www.myqnap.org/product/lidarr81/
Apache82 : https://www.myqnap.org/product/lidarr82/
use port 8686 by default
Lidarr is a music collection manager for Usenet and BitTorrent users. It can monitor multiple RSS feeds for new tracks from your favorite artists and will grab, sort and rename them. It can also be configured to automatically upgrade the quality of files already downloaded when a better quality format becomes available.
Major Features Include:
Support for major platforms: Windows, Linux, macOS, Raspberry Pi, etc.
Automatically detects new tracks.
Can scan your existing library and download any missing tracks.
Can watch for better quality of the tracks you already have and do an automatic upgrade.
Automatic failed download handling will try another release if one fails
Manual search so you can pick any release or to see why a release was not downloaded automatically
Fully configurable track renaming
Full integration with SABnzbd and NZBGet
Full integration with Kodi, Plex (notification, library update, metadata)
Full support for specials and multi-album releases
And a beautiful UI
Last edited by QNAP_Stephane on Wed Jan 25, 2023 7:01 pm, edited 9 times in total.
Re: [ Lidarr .NET ] [ 0.7.1.1712 ] Looks and smells like Sonarr but made for music (Dot Net version)
Any plans to do one of these for Radarr .net version?
Would be much appreciated.
QNAP TS-653 Pro -- with 16Gb RAM
6 * Western Digital WD60EFRX WD Reds (RAID5) as a Single 27.1TB Volume
Firmware: QTS 5.0.1.2277
- QNAP_Stephane
is there any ? i can only find Mono Version
I'd installed the standard qpkg, changed the branch to 'aphrodite'
-- which upgraded me to Radarr 3 using the built-in mechanism.
-- which is working fine, but shares the message "Please upgrade to the .NET Core version of Radarr"
.. with this link: https://github.com/Radarr/Radarr/wiki/H ... re-version
- QNAP_Stephane
ok i will work on it
- QNAP_Stephane
built : https://www.qnapclub.eu/fr/qpkg/1007rs1001 wrote: ↑Wed Jul 22, 2020 7:31 pm I'd installed the standard qpkg, changed the branch to 'aphrodite'
Thank you so much!
- Trexx
Seeing the following errors in Lidarr (.Net). Any ideas?
Certificate validation for https://services.lidarr.audio/v1/update/master/changes?version=0.7.1.1712&os=linux&runtimeVer=3.1.5&active=false failed. RemoteCertificateChainErrors
Request Failed. GET /api/v1/update: The SSL connection could not be established, see inner exception. The remote certificate is invalid according to the validation procedure.: 'https://services.lidarr.audio/v1/update/master/changes?version=0.7.1.1712&os=linux&runtimeVer=3.1.5&active=false'
System.Net.WebException: The SSL connection could not be established, see inner exception. The remote certificate is invalid according to the validation procedure.: 'https://services.lidarr.audio/v1/update/master/changes?version=0.7.1.1712&os=linux&runtimeVer=3.1.5&active=false'
---> System.Net.WebException: The SSL connection could not be established, see inner exception. The remote certificate is invalid according to the validation procedure.
---> System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
at System.Net.Security.SslStream.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception)
at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslStream.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest)
--- End of stack trace from previous location where exception was thrown ---
at System.Net.Security.SslStream.ThrowIfExceptional()
at System.Net.Security.SslStream.InternalEndProcessAuthentication(LazyAsyncResult lazyResult)
at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result)
at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult)
at System.Net.Security.SslStream.<>c.<AuthenticateAsClientAsync>b__65_1(IAsyncResult iar)
at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)
--- End of inner exception stack trace ---
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean allowHttp2, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.GetHttpConnectionAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.DiagnosticsHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.FinishSendAsyncUnbuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts)
at System.Net.HttpWebRequest.SendRequest()
at System.Net.HttpWebRequest.GetResponse()
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in d:\a\1\s\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:line 80
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in d:\a\1\s\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:line 110
at NzbDrone.Common.Http.HttpClient.ExecuteRequest(HttpRequest request, CookieContainer cookieContainer) in d:\a\1\s\src\NzbDrone.Common\Http\HttpClient.cs:line 127
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in d:\a\1\s\src\NzbDrone.Common\Http\HttpClient.cs:line 61
at NzbDrone.Common.Http.HttpClient.Get(HttpRequest request) in d:\a\1\s\src\NzbDrone.Common\Http\HttpClient.cs:line 268
at NzbDrone.Common.Http.HttpClient.Get[T](HttpRequest request) in d:\a\1\s\src\NzbDrone.Common\Http\HttpClient.cs:line 274
at NzbDrone.Core.Update.UpdatePackageProvider.GetRecentUpdates(String branch, Version currentVersion) in d:\a\1\s\src\NzbDrone.Core\Update\UpdatePackageProvider.cs:line 74
at NzbDrone.Core.Update.RecentUpdateProvider.GetRecentUpdatePackages() in d:\a\1\s\src\NzbDrone.Core\Update\RecentUpdateProvider.cs:line 27
at Lidarr.Api.V1.Update.UpdateModule.GetRecentUpdates() in d:\a\1\s\src\Lidarr.Api.V1\Update\UpdateModule.cs:line 21
at Lidarr.Http.REST.RestModule`1.<set_GetResourceAll>b__33_0(Object options) in d:\a\1\s\src\Lidarr.Http\REST\RestModule.cs:line 136
at Nancy.NancyModule.<>c__DisplayClass14_0`1.<Get>b__0(Object args)
at Nancy.NancyModule.<>c__DisplayClass16_0`1.<Get>b__0(Object args, CancellationToken ct)
at Nancy.Routing.Route`1.Invoke(DynamicDictionary parameters, CancellationToken cancellationToken)
at Nancy.Routing.DefaultRouteInvoker.Invoke(Route route, CancellationToken cancellationToken, DynamicDictionary parameters, NancyContext context)
at Nancy.Routing.DefaultRequestDispatcher.Dispatch(NancyContext context, CancellationToken cancellationToken)
at Nancy.NancyEngine.InvokeRequestLifeCycle(NancyContext context, CancellationToken cancellationToken, IPipelines pipelines)
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- QNAP_Stephane
may be open an issue on github... may be flag to add in command line... but really not sure
Apache4 installed and update latest ca-certicates.crt and also is using a recent openssl 1.1.1g
- QNAP_Stephane
think i found why...
.crt must be also into /opt/Apache74/ssl/certs
what i do :
it should generate ca-bundle.crt
just
error should disappear
what i do :
export PATH=/opt/Apache74/bin:$PATH
wget https://raw.github.com/bagder/curl/master/lib/mk-ca-bundle.pl
chmod +x mk-ca-bundle.pl
./mk-ca-bundle.pl
just
cp ca-bundle.crt /opt/Apache74/ssl/certs/
- QNAP_Stephane
on my test it is fixed with latest Apache74 wth php 7.4.09
- QNAP_Stephane
Re: [ Lidarr .NET ] [ 0.7.1.1780 ] Looks and smells like Sonarr but made for music (Dot Net version)
updated
- Skeptical.me
- Easy as a breeze
QTS 4.5.1.1495
NAS Model: QNAP TS-253Be
The folder the Torrents are downloaded to is /Share/CE_CACHEDEV1_DATA/Download/Download/
That path is the "Default Save Path" in QBitTorrent Options.
When a torrent is grabbed via Lidarr, it sends it to QBitTorrent. Once the download is completed Lidarr tells me ""... this directory does not appear to exist. Likely missing remote path mapping"
Apparently I need to change the permissions and allow Lidarr access to /Share/CE_CACHEDEV1_DATA/Download/Download/
How do I do that? I'm not sure how to change permissions for an application (Lidarr).
QNAP TS-253Be 2 x WD Red 6TB RAID1, & 1 x WD Ext. 6TB, QTS: 4.5.3.1670
Plex, Radar, Sonarr, Lidarr, NZBGet, NZBHydra 2, Container Station
I can't install this app, it says I fist need to install and start Apache74. How do I do so ?
Thanks a lot
- QNAP_Stephane
Read first page ... you have link for Apache74
