[ WordPress (Apache74) ][ 5.4.2.1 ] WordPress to create a beautiful website, blog, or app
Source : https://wordpress.org/
Download : https://www.qnapclub.eu/en/qpkg/860
Changelog :
About :
Create a beautiful website, blog, or app.
Re: [ WordPress (Apache74) ][ 5.4.2 ]
Hello everyone,
after downloading and installing "WordPress74_5.4.2.0_*.qpkg" I've and found several issues.
Issues:
Issues:
- In the AppCenter I click on the app to open it, then it opens a new tab with the address http://192.168.0.1:54326. If this WordPress QPKG is for the Apache74, which listening per default on the HTTP port 3288 and HTTPS port 448, then the port 54326 is wrong configured. Is There a way to fix the port?
- The package is installed to "/opt/WordPress74/". In this root folder there is a "httpd.conf" and inside this text file there is this line: ' ServerRoot "/opt/Apache73" '. Shouldn't be this "/opt/Apache74"? Is this the reason why it doesn't work?
- When I open the text file WordPress.sh I can see how the ports are configured:
- #export LISTENHTTP=54326
- export LISTENHTTP=3288
- #export LISTENHTTPS=54327
- export LISTENHTTPS=448
- QNAP_Stephane
Re: [ WordPress (Apache74) ][ 5.4.2 ] WordPress to create a beautiful website, blog, or app
Will double check
Envoyé de mon MI 9 en utilisant Tapatalk
- QNAP_Stephane
fixed in 5.4.2.1
It works flawlessly now. Thanks QNAP_Stephane. Merci beaucoup de l'Allemagne.
Re: [ WordPress (Apache74) ][ 5.4.2.1 ] WordPress to create a beautiful website, blog, or app
Hello to all users of the "WordPress74_5.4.2.1_*.qpkg" and newer,
here is a brief manual for this QPKG. I hope it will help you to enjoy it.
This is an inofficial manual as I'm only a customer like you and I don't get paid for my work. Use at your own risk.
Table of contents
1. Annotation
2. Download issues on QNAPclub.eu
3. WordPress installation folder
4. Start the WordPress installation
5. French installation instructions in your mother tongue
6. Database connection details
7. Use the WordPress command line WP-CLI
8. Security through obscurity
9. Restart WordPress
10. Remote Access via SSH to your station
11. Glossary
1. Annotation
Please help to support the community by letting me know, if there is a mistake, how to explain in a better way and what is missing. Please don't hesitate and send a message.
It doesn't matter if you try to download a QPKG directly from QNAPclub.eu, from the freeware repository or your unique store link. Sometimes, especially with large files, your download will fail because of network errors.
The fix is easy and costs you only patience. After your download has failed, try again and again. You will see, after several tries you will manage your download successfully.
Connect with PuTTY or WinSCP to your station, then navigate to "/share/CE_CACHEDEV1_DATA/.qpkg/WordPress74".
You can start the installation from your "App Center" by clicking on the button "◦ Open" or directly open a new tab in your browser and open "https://<<station's_IP_address>>:54326/wp-admin/setup-config.php".
As you can see, this QPKG contains the French language version of WordPress. If you can't read French, there are two ways to use WordPress in your mother tongue.
Option A
Use the feature Google Translate, which is built-in the Google Chrome browser. You'll find the translation icon in the address bar on the far right. Click on this icon and select your mother tongue. Once you've finished the installation and log in to WordPress you can download your desired language pack.
Option B
If you use this WordPress QPKG together with Qnapclub's QMariaDB and didn't change so far the default password for a MariaDB, then fill in the form these settings:
Please read [HOW-TO] WP-CLI: Command line interface for WordPress.
To increase the security of your WordPress installation it is recommend to delete the "readme.html" and "license.txt" from the root folder of WordPress. This kind of protection is called "Security through obscurity". So imagine, that nowhere you mentioning, that you use WordPress as a CMS. If e. g. an attacker type this address "http://www.<<domain_name>>.<<TLD>>/readme.html" he/she finds links in this document which will lead to the WordPress login page for admins. With both documents you give not only evidence about the CMS you're using also on the approximate version of WordPress you've have currently in use. Like any software on this planet also WordPress has bugs and much more important security threat.
Once the attacker reached your login form, it is predestined for for dictionary attacks aka brute-force attacks.
9. Remote Access via SSH to your station
You must install, or simply use their portable versions, WinSCP or PuTTY. I recommend you both, because with PuTTY you can restart services on you station and with WinSCP it is much more comfortable to navigate through your station's folders and to edit files. Please be aware to first check in QNAP's "ControlPanel", category "Network & File Services" and sub-category "Telnet /SSH" the checkbox "Allow SSH connection" (used for WinSCP and PuTTY) and "Enable SFTP" (used for WinSCP).
11. Glossary
Table of contents
1. Annotation
11. Glossary
1. Annotation
Option A
Option B
- Visit https://wordpress.org and have it displayed in your mother tongue.
- Download a free copy of the most current WordPress version.
- Extract the downloaded ZIP file.
- Log in with WinSCP to your station.
- Navigate to the installation directory of WordPress, then open the folder "www".
- Overwrite all content by with the WordPress version in your mother tongue by drag and drop.
- Database Name: wordpress
- Username: root
- Password: qnap
- Database Host: localhost:3308
- Table Prefix: wp_
- Password: <<The password which you set in the "Control Panel" in category "Applications" in sub-category "SQL server" in the chapter "Database Maintenance".>>
- Database Host: localhost:3306
- Login your station and open the "App Center".
- In the category "QNAP Store" in the sub-category "My Apps" search for "WordPress (Apache74)".
- Click on the blue button with the down arrow and select "Stop".
- After a short waiting time this app is stopped and the blue button turns into black.
- To start the app again click on the black button "• Start" to start WordPress again.
11. Glossary
- C
- CMS is the abbreviation of content management system.
- P
- PuTTY is a free and open-source terminal emulator, serial console and network file transfer application. It supports several network protocols, including SCP, SSH, Telnet, rlogin, and raw socket connection. Get it from the official website: https://www.chiark.greenend.org.uk/~sgtatham/putty/
- T
- A top-level domain (TLD) is one of the domains at the highest level in the hierarchical Domain Name System of the Internet. Examples: .com, .org, .fr, .co.uk, .ch, ...
- W
- WinSCP (Windows Secure Copy) is a free and open-source SFTP, FTP, WebDAV, Amazon S3 and SCP client for Microsoft Windows. Get it from the official website: https://winscp.net
Looking at the Qnabclub Store (see screenshot) I guess this .qpkg is still supported by @QNAP_Stephane (aka Qoolbox?). See the newer versions.
