[ MUSL ToolChain/Framework ] [ 11.1 formely 1.2.2 ] Add MUSL Cross tools & Framework
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
source : https://wiki.musl-libc.org
Download :
: https://www.myqnap.org/product/musl-framework/
install on your NAS the MUSL Cross toolchain built with crosstool-ng
it allow to compile directly on your NAS with GCC 9.3 (only on a NAS x86_64 Intel/amd).. other compilaton tools are also embedded (make, autoconf, bison, libtool...)
because musl run under another ELF this package needs to be installed on NAS to execute the cross compiled application
on x86_64 NAS, it modify .profile of your /root (admin session in SSH) and export necessary FLAG to compile
HOST=x86_64-QNAP_-linux-musl
export HOST
TOOLCHAIN_PATH=/root/x-tools/x86_64-QNAP_-linux-musl
export TOOLCHAIN_PATH
PATH=$PATH:$HOME/bin:${TOOLCHAIN_PATH}/bin:${TOOLCHAIN_PATH}/x86_64-QNAP_-linux-musl/bin
export PATH
call $HOST in your autoconf source will call all necessary toolcahin artefacts
exemple for openssl $PREFIX location should be exported first (location where source will compiled)
PKG_CONFIG_PATH="${PREFIX}/lib/pkgconfig" \
CFLAGS="-O2 -I${PREFIX}/include" \
CXXFLAGS="-O2 -I${PREFIX}/include" \
LDFLAGS="-L${PREFIX}/lib -Wl,-rpath,${PREFIX}/lib -Wl,-rpath,/root/x-tools/x86_64-QNAP_-linux-musl/lib -Wl,-rpath,/root/x-tools/x86_64-QNAP_-linux-musl/x86_64-QNAP_-linux-musl/lib64 -Wl,--dynamic-linker=/root/x-tools/x86_64-QNAP_-linux-musl/x86_64-QNAP_-linux-musl/sysroot/lib/ld-musl-x86_64.so.1" \
CPPLFAGS="-O2 -I${PREFIX}/include" \
FFLAGS="-O2 -I${PREFIX}/include" \
./Configure "-L${PREFIX}/lib -Wl,-rpath,${PREFIX}/lib -Wl,-rpath,${PREFIX}/lib -Wl,-rpath,/root/x-tools/x86_64-QNAP_-linux-musl/lib -Wl,-rpath,/root/x-tools/x86_64-QNAP_-linux-musl/x86_64-QNAP_-linux-musl/lib64 -Wl,--dynamic-linker=/root/x-tools/x86_64-QNAP_-linux-musl/x86_64-QNAP_-linux-musl/sysroot/lib/ld-musl-x86_64.so.1" "-I${PREFIX}/include" --prefix=${PREFIX} --openssldir=/etc/ssl --cross-compile-prefix=${HOST}- enable-tls1_3 shared no-zlib linux-x86_64
make -j$(nproc) && make install
here i added a dynamic linker to be sure source will go pick the right ld location...
NOTE
not sure Compiled on NAS directly is right solution, (should miss many thing) but you can download my MUSL ToolChains on an Ubuntu and extract it in side /root
personnlay i am using an ubuntu LXC x86_64 to do it
https://mega.nz/file/hgBjFAhZ#zU3zg-dRk ... z2_e-F9m4
next create in root a .bash_profile with inside
export HOST
export PATH
and restart your SSH to make change apply to the current session
other toolchain for aarch64 , arm, x86 (32bit intel) are also available you just need modify path to be able to cross compile for this architecture
to run a cross compiled application, MUSL must be installed on host NAS to be able to execute the right ELF
Last edited by QNAP_Stephane on Thu Dec 08, 2022 1:09 am, edited 2 times in total.
OneCD
Re: [ MUSL ToolChain/Framework ] [ 9.3 formely 1.2.1 ] Add MUSL Cross tools & Framework
Post by OneCD »
Hi Stephane, can you please confirm the internal package name for this one? Is it 'MUSL_CROSS' ?
QNAP_Stephane
Experience counts
OneCD wrote: Fri Jun 04, 2021 3:11 am Hi Stephane, can you please confirm the internal package name for this one? Is it 'MUSL_CROSS' ?
Hello , yes exactly
OneCD
Post by OneCD »
Cheers mate. :)
QNAP_Stephane
Experience counts
Re: [ MUSL ToolChain/Framework ] [ 11.1 formely 1.2.2 ] Add MUSL Cross tools & Framework
updated to 11.1
GCC 11.1
MUSL Core to 1.2.2
fixed for ARMv7 (wrong symlinking)
updated to latest libs, headers and companion tool
andgiamp
Post by andgiamp »
Just a question, is it possible to install this framework on my TS-230 with AMD64 processor?
QNAP_Stephane
Experience counts
yes you can... but only aarch64 binaries could be launched
andgiamp
Post by andgiamp »
Thx a lot for the reply.
is there somewhere a step by step guide to install the binaries?
Thx a lot
jallen1227
First post
Post by jallen1227 »
Hi Stephanie, thanks.
Good at following instructions typically but bit challenged here on the description.
Based upon your message above from Sun Apr 04, 2021 3:02 am, sounds like no additional work is necessary from the user with you describing everything you completed as part of the MUSL coding and changes made during the install process.
Just wanting to confirm as I am trying to get MPD working on my QNAP.
Thanks,
Jeff
lollodragon
Post by lollodragon »
QNAP_Stephane wrote: Sun Apr 04, 2021 6:02 pm source : https://wiki.musl-libc.org
Download :
https://www.qnapclub.eu/fr/qpkg/1098
I'm sorry but the download page doesn't work. Can somebody check the url? Than you!!!
QNAP_Stephane
Experience counts
Return to “Community Apps”
