[ CloudFlared ] [ 2023.02.1] Argo Tunnel client
- QNAP_Stephane
Source : https://github.com/cloudflare/cloudflared
Download
https://www.myqnap.org/product/cloudflare-argo-tunnel/
Contains the command-line client for Argo Tunnel, a tunneling daemon that proxies any local webserver through the Cloudflare network. Extensive documentation can be found in the Argo Tunnel section of the Cloudflare Docs.
Last edited by QNAP_Stephane on Sat Feb 04, 2023 3:44 pm, edited 5 times in total.
- QNAP_Stephane
Re: [ CloudFlared ] [ 2021.6.0] Argo Tunnel client
bump to 2021.6.0
Nice, but small question: any QNAP specific doc about how do you stop/start the service?
- QNAP_Stephane
you can set your start /stop script within
/opt/CloudFlared/CloudFlared.sh
in start {
and
stop {
sections
in start {
and
stop {
sections
Re: [ CloudFlared ] [ 2021.9.0] Argo Tunnel client
Do you know which version I need to install for this NAS model: TVS-871-i7-16G (EOL), CPU Intel® Core™ i7-4790S 4-core 3.2 GHz processor, CPU Architecture 64-bit x86
These versions are available in the QnapClub repo:
TS-NASX86
TS-X41
TS-NASARM_64
TS-X28A
TS-X30
TS-X32
TS-X32U
TS-XA28A
TS-ARM-X19
TS-NASX86_64
TS-X31
TS-NASX86
TS-X41
TS-NASARM_64
TS-X28A
TS-X30
TS-X32
TS-X32U
TS-XA28A
TS-ARM-X19
TS-NASX86_64
TS-X31
NASX86_64
as you already discovered that you have a x86/x64 NAS
Yeah, that's what I tried, but it doesn't seem to work...
Re: [ CloudFlared ] [ 2021.11.0] Argo Tunnel client
and that means ?..error message of any sort?
After authenticating with cloudflare, I try to create tunnel like:
cloudflared tunnel create anything
2021-11-24T15:48:32Z INF Cannot determine default origin certificate path. No file cert.pem in [~/.cloudflared ~/.cloudflare-warp ~/cloudflare-warp /etc/cloudflared /usr/local/etc/cloudflared] originCertPath=
2021-11-24T15:48:32Z ERR You need to specify the origin certificate path with --origincert option, or set TUNNEL_ORIGIN_CERT environment variable. See https://developers.cloudflare.com/argo- ... arguments/ for more information. originCertPath=
failed to create tunnel: couldn't create client to talk to Cloudflare Tunnel backend: Error locating origin cert: client didn't specify origincert path when running from terminal
This error message comes.
I cannot locate the cert.pem file although Cloudflare says authentication is OK:
Success
Cloudflared has installed a certificate allowing your origin to create an Argo Tunnel on this zone.
You may now close this window and start your Argo Tunnel!
Success
k,so it has nothing to do with the wrong installation package then, so you would have to wait for QNAP_Stephane to check and/or compile a new version (if that is the issue)
- QNAP_Stephane
Re: [ CloudFlared ] [ 2022.12.0] Argo Tunnel client
updated to 2022.12.0
Can anyone help a linux noob plz. I can't migrate from argo tunnel to cloudflare zero trust
could anyone advise as to what I need to do
TIA
TIA
- QNAP_Stephane
Re: [ CloudFlared ] [ 2023.1.0] Argo Tunnel client
updated to 2023.1.0
. when I type
Thanks v much for that. As mentioned previosly very new to qnap cli when I type CloudFlared.sh {start} i get command not found. if you or someone else could guide me I's be immensly grateful. TIA to any & all who can assist
- QNAP_Stephane
it is not in startup scriptStackoverflow wrote: ↑Wed Jan 25, 2023 6:54 pm. when I type
use :
$QPKG_ROOT/cloudflared or /usr/bin/cloudflared (symlink)
