[QClamAV] [0.103.2.1]
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
yanuk
Know my way around
Post by yanuk »
Found this in the repo but not documented here so I thought I'll start a new thread for this
https://qnapclub.eu/en/qpkg/1091
All thanks to Stephane our tireless qpkg maker! Thank you!
Works and easy to configure.
I've added additional malware definition from LMD into /opt/ClamAV/etc/freshclam.conf (to the end of the file)
DatabaseCustomURL http://www.rfxn.com/downloads/rfxn.ndb
DatabaseCustomURL http://www.rfxn.com/downloads/rfxn.hdb
DatabaseCustomURL http://www.rfxn.com/downloads/rfxn.yara
TS451
TS453
TVS-682
erictw
First post
Re: [QClamAV] [0.103.1]
Post by erictw »
I can't install on my qnap (TS-220 QTS4.3.3.1432)
dolbyman
Post by dolbyman »
yes..no x19 kirkwood version for download
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
oops sorry yes forgot to publish it here..
it is for moment only a prerelease, no armv5 for moment du lack of time and require a recent gcc (may be a chance to cross compile it with MUSL Toolchain, but i need more time fir that)
no sure if it can be a replacement for the actual firmware version to bring a more easier configuration setup.
it actally by default scan all in the /share path
Skeptical.me
Easy as a breeze
Post by Skeptical.me »
Is there a Command Line interface to this? I notice in the processes that clamscan, and clamd are working, but I have no idea if viruses are found, or where the quarantine folder is.
QNAP TS-253Be 2 x WD Red 6TB RAID1, & 1 x WD Ext. 6TB, QTS: 4.5.3.1670
Plex, Radar, Sonarr, Lidarr, NZBGet, NZBHydra 2, Container Station
yanuk
Know my way around
Post by yanuk »
You can run command lines from the binaries in /opt/ClamAV/bin
TS451
TS453
TVS-682
yanuk
Know my way around
Post by yanuk »
Not sure why, but my QClamAV seem to stop running after a few days.
So I wrote a script to restart it whenever it stops and put it in crontab that executes every 5 mins
#!/bin/bash
if  [[ $(lsof -i :3318 | grep -i clamd | wc -l) -eq 0 ]]; then
    /etc/init.d/ClamAV.sh start
     /sbin/log_tool --append "QClamAV was down, restarted." --type=1
fi
save the file to somewhere permanent like /share/Download/checkav.sh and chmod +x checkav.sh
point your crontab there and it will restart whenever we don't find clamd at port 3318. change 3318 to any other ports you use.
Edit: added an alert to QNAP notifications to give a Warning that QClamAV was detected to be down and started up.
TS451
TS453
TVS-682
yanuk
Know my way around
Re: [QClamAV] [0.103.2.1]
Post by yanuk »
Hi @QNAP_Stephane I upgraded o 0.103.2.1 and starting clamd now produces a lot of warnings
LibClamAV Warning: cli_loadyara: YARA.gate_php_js uses PCREs but support is disabled
LibClamAV Warning: load_oneyara: clamav cannot support 1 input strings, skipping YARA.gate_php_js
LibClamAV Warning: cli_loadyara: YARA.Backdoor_PHP_WPVCD_TempExecution uses PCREs but support is disabled
LibClamAV Warning: load_oneyara: clamav cannot support 1 input strings, skipping YARA.Backdoor_PHP_WPVCD_TempExecution
LibClamAV Warning: cli_loadyara: YARA.Backdoor_PHP_WPVCD_DivCodeName uses PCREs but support is disabled
LibClamAV Warning: load_oneyara: clamav cannot support 1 input strings, skipping YARA.Backdoor_PHP_WPVCD_DivCodeName
LibClamAV Warning: cli_loadyara: YARA.Backdoor_PHP_WPVCD_Deployer uses PCREs but support is disabled
Mon Aug 22 15:46:50 2022 -> !LOCAL: Socket file /tmp/Qclamd.socket is in use by another process.
and clamd doesn't load. is there any dependencies we need to install before this?
TS451
TS453
TVS-682
yanuk
Know my way around
Post by yanuk »
hi @QNAP_Stephane Any intention to update this to v1.3?
TS451
TS453
TVS-682
Toxic17
Ask me anything
Contact:
Post by Toxic17 »
all of Stephane's current projects are on https://www.myqnap.org/ I suggest you ask on the myqnap discord server. anything on qnapclub is unsupported.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Return to “Community Apps”
