[ APC Powerchute Network Shutdown ] [ 4.4.1 ] Network-based, graceful, unattended shutdown
- QNAP_Stephane
Source : https://www.apc.com/shop/fr/fr/categori ... n/N-auzzn7
Download : x64 only
https://www.myqnap.org/product/powerchute/
PowerChute Network Shutdown works in conjunction with the APC UPS Network Management Card to protect your physical and virtual IT environment from threats to IT availability. Network-based, graceful, unattended shutdown of your physical servers and virtual machines protects data integrity and reduces system downtime when critical events such as extended power outages occur. Its scalable architecture can support a virtually unlimited number of client systems. PowerChute Network Shutdown is easily configurable via a browser interface and supports Single, Redundant and Parallel UPS configurations.
QPK Integration :
Listen on port 6547 (HTTPS)
Re: [ APC Powerchute Network Shutdown ] [ 4.4.1 ] Network-based, graceful, unattended shutdown
Hello Stephen,
Are you abler to update this app to include the vmware virtualisation version? ( your Version is non esxi vmware)
This is the OVA used on Vmware. basically Linux package..
https://www.apc.com/us/en/product/SFPCN ... 7602445705
Thanks.
Thanks.
- QNAP_Stephane
hi dont understand the request... actually Linux version is 4.4.1
i just updated the link : https://www.myqnap.org/product/powerchute/
Hello, If I logout it asks me again for a user and password, and I don't recall that I typed them, are there any default ones?
Thanks!
Thanks!
Where is user info saved? I lost password and then uninstalled the Powerchute and deletet APC folder from /share/ZFS530_DATA/.qpkg location. After installing again, the wizard does not start and it is asking credentials to login?
Maybe in the qpkgconf file..if you have already deleted the whole install directory
Hmm.. Where is this qpkgconf file? Cannot find it from my nas... (TVS-h1288x with QuTS Hero)
check under
/etc/config/qpkg.conf
Sorry, out of ideas where the config files could be then, hope QNAP_Stephane replies soon
