[ Prowlarr ] [ 1.0.1.2220 ] An indexer manager/proxy built on the popular *arr
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
Source : https://github.com/Prowlarr/Prowlarr
Download : x64, arm64
Apache80 : https://www.myqnap.org/product/prowlarr80/
Apache81 : https://www.myqnap.org/product/prowlarr81/
Apache82 : https://www.myqnap.org/product/prowlarr82/
Prowlarr supports both torrent trackers and Usenet indexers. It integrates seamlessly with Lidarr, Radarr, Readarr, and Sonarr, offering automated management of your indexers with no per-app indexer configuration required (we do it all!).
We're currently releasing this as a beta, with a formal stable release coming in the near future. You may encounter some bugs, but the closed-alpha testers have been running Prowlarr in production for several months now with great success.
Prowlarr brings an all in one solution for both torrent and usenet indexer management, incorporating the best features from other applications into a familiar UI.
Features include:
Speedy (.NET 5 backend with ReactJs UI)
Usenet support for any Newznab compatible indexer, including Headphones VIP
Torrent support for 400+ trackers, and more coming soon
Indexer Sync to Sonarr/Radarr/Readarr/Lidarr, so manual configuration of the other applications is not required
Indexer History and Statistics
Manual Searching of Trackers & Indexers at a category level
Support for pushing releases directly to your favorite download clients from Prowlarr
Last edited by QNAP_Stephane on Fri Jan 06, 2023 4:36 pm, edited 3 times in total.
pjbeal
First post
Re: [ Prowlarr ] [ 0.1.0.361 ] An indexer manager/proxy built on the popular *arr
Post by pjbeal »
Can i get this anywhere else as qnap club been down over a week?
jmnrPT
Post by jmnrPT »
Does this have a x41 package?
Thwomp
Post by Thwomp »
Is it possible for a native x64 package that doesn't require Apache?
giopas
Been there, done that
Post by giopas »
If you want, and you have Container Station installed, you can use the docker version by running this command in ssh:
sudo docker run -d --name=prowlarr -e PUID=1000 -e PGID=1000 -e TZ=Europe/Luxembourg -p 9696:9696 -v /path/to/data:/config --restart unless-stopped lscr.io/linuxserver/prowlarr:develop
Qnap TS-253Pro 16Gb RAM - Single Storage Pool: 2 WRed 4TB (RAID 1)
Qnap TS-453A 16Gb RAM - Single Storage Pool: 4 WRed 4TB (RAID 5)
QNAP_Stephane
Experience counts
Re: [ Prowlarr ] [ 0.4.7.2016 ] An indexer manager/proxy built on the popular *arr
updated to latest version - new link repo
QNAP_Stephane
Experience counts
Re: [ Prowlarr ] [ 1.0.1.2220 ] An indexer manager/proxy built on the popular *arr
updated to latest + Apache82 version added
MilesB
Post by MilesB »
Hi All,
Having issues with my Rarbg indexer so looking at Prowlarr - I'm a bit rusty in setting this up as its been set and forget for quite a few years.
I have a QNAP TS-251+
Can someone confirm the download version I need to install, and perhaps point me to any setting etc that could be helpful.
Blisk
Know my way around
Post by Blisk »
Prowlarr stops to work on my qnap. web UI doesn't work, but in APP center I can see it is started.
Prowlarr is Prowlarr81_1.13.2.425_x86_64.qpkg
and my qnap version is QTS 5.1.4.2596
Return to “Community Apps”
