NextCloud by Qoolbox
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
Komba
Post by Komba »
Hey there,
I just noticed that my NextCloud app (https://www.qnapclub.eu/pl/qpkg/348) is still at version 20.0.1.0 while the most recent version available in the store is 21.0.0 (sceenshot). As you also can see on the screenshot, it looks like a new app, like if I would not already have it installed (but it is). Ofcourse when I click "Install" it won't update but try to install it, giving me an Error that an App with the same name already is installed. How can I safely migrate to version 21.0.0 without dataloss or the need of reconfiguring everything? I'm using a TS-453BE with the most recent firmware.
Thanks alot in advance <3
dolbyman
Re: NextCloud by Qoolbox
Post by dolbyman »
Check the official thread
viewtopic.php?f=320&t=124954&start=540
Qoolbox/Qnap_Stephane builds the qpkg's from source, but does not use it (according to a recent forum post)
Major version updates are also unsupported (see first post in the topic)
Return to “Community Apps”
