[ PHP-FPM8 ] [ 8.0.27 ] PHP Replacement to branch 8.0.x for QTS embbeded Web Server
This is the best place for community developers to publish their genius work. Your Apps enrich the QNAP Turbo NAS.
QNAP_Stephane
Experience counts
Post by QNAP_Stephane »
Source : https://www.php.net/
Download : amd64, arm64
https://www.qnapclub.eu/fr/qpkg/1191
about :
Replace the embedded Qnap PHP version to latest 8.0.x branch
configuration file directory : /opt/PHPFPM8/etc
logs directory : /opt/PHPFPM8/var/log
be carefull : some php applications are not yet compatible with PHP 8.0.x branch
disabling this qpkg, make you roll back to Qnap embedded PHP-FPM 7.3
php error logs enable by default :
cross compiled with the following modules enabled :
[PHP Modules]
amqp
apcu
bcmath
bitset
bz2
calendar
Core
ctype
curl
date
dba
dom
eio
ev
event
exif
fileinfo
filter
ftp
gd
geoip
gettext
gmp
gnupg
grpc
hash
hprose
hrtime
http
iconv
igbinary
imagick
inotify
intl
json
krb5
ldap
libxml
mailparse
mbstring
mcrypt
memcached
mongodb
msgpack
mysqli
mysqlnd
OAuth
odbc
openssl
pcntl
pcre
PDFlib
PDO
pdo_dblib
pdo_mysql
PDO_ODBC
pdo_pgsql
pdo_sqlite
pgsql
Phar
posix
propro
pspell
radius
raphf
readline
redis
Reflection
scrypt
session
shmop
SimpleXML
snmp
soap
sockets
sodium
solr
SPL
sqlite3
standard
swoole
taint
tidy
timezonedb
tokenizer
xattr
xdebug
xml
xmlreader
xmlrpc
xmlwriter
xsl
xxtea
yaml
Zend OPcache
zip
zlib
[Zend Modules]
Xdebug
Zend OPcache
Last edited by QNAP_Stephane on Mon Jan 09, 2023 11:10 pm, edited 1 time in total.
WeT-Klb
Re: [ PHP-FPM8 ] [ 8.0.10 ] PHP Replacement to branch 8.0.x for QTS embbeded Web Server
Post by WeT-Klb »
Nextcloud 23 has this warning:
Ihr PHP unterstützt Freetype nicht. Dies wird defekte Profilbilder und eine defekte Anzeige der Einstellungen verursachen.
Is it possible to add support for Freetype to PHP-FPM8?
OneCD
Post by OneCD »
WeT-Klb wrote: Wed Jan 19, 2022 3:16 am Ihr PHP unterstützt Freetype nicht. Dies wird defekte Profilbilder und eine defekte Anzeige der Einstellungen verursachen.
This is an English-language-only forum. Please post only in English. Thank you.
WeT-Klb
Post by WeT-Klb »
Your PHP does not support freetype. This will cause broken profile images and settings display.
DAveDS
Post by DAveDS »
Hey,
I update to PHP-FPM 8 successfully, but had one issue:
By GD extension is the freeType and JPEG not supporting
by running a script to check the GD i got this:
Yes
FreeType SupportNo
GIF Read SupportYes
GIF Create SupportYes
JPEG SupportNo
PNG SupportYes
WBMP SupportYes
XPM SupportNo
XBM SupportYes
WebP SupportNo
BMP SupportYes
TGA Read SupportYes
JIS-mapped Japanese Font SupportYes
But when i look in PHPinfo i see by the configure command it's ok:
enable-gd' '--with-webp-dir=/opt/PHPFPM8' '--with-jpeg-dir=/opt/PHPFPM8' '--with-png-dir=/opt/PHPFPM8' '--with-freetype-dir=/opt/PHPFPM8' '--with-t1lib=/opt/PHPFPM8' '--enable-gd-native-ttf' '--enable-gd-jis-conv'
i see above freestyle isn't compatible but what about the jpgeg?
Someone else run in the same issue and has a solution? (when server starts JPEG and freetype are ok, but after a few minutes when the php-fpm8 is loaded the jpeg and freetype aren't enabled anymore --> I find out that the server starts with php7.3 and loads the qpkg a little bit later)
thanks
Davy
QNAP_Stephane
Experience counts
Re: [ PHP-FPM8 ] [ 8.0.27 ] PHP Replacement to branch 8.0.x for QTS embbeded Web Server
updated to PHP 8.0.27
libs updated (openssl, freetype, gd)
fixed GD not including freetype2 and jpeg
Toxic17
Ask me anything
Contact:
Post by Toxic17 »
QNAP_Stephane wrote: Mon Jan 09, 2023 11:10 pm updated to PHP 8.0.27
cant seem to find this on myqnap.org, yet you posted the above update on Mon Jan 09, 2023 3:10 pm
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Return to “Community Apps”
