Hi
I'm using the syslog server element of my QNAP TS453-Pro more and more, now all the compatible items in my house are reporting there, even subtle changes in my Home Automation set up (temp, motion, light readings etc) are being captured
As it seems to be free for use for home use, is there scope to have Splunk added to the QNAP supported apps?
http://www.splunk.com/download?ac=ga010 ... Aizt8P8HAQ
As I have the intel based processor which option listed above that I could use to make my messages.csv syslog data available and analysed by Splunk?
Splunk - Log analyser
- parkerc
- Easy as a breeze
Model Name : QNAP TS-253be (16GB) & TS-453D (16GB)
Firmware Version:: QTS Latest
OS Version : Apple iOS (iPad/Safari Browser)
Number & Type of HDDs : 2 x 3TB WD Reds, Raid 1 & 4 x 4TB WD Reds, Raid 5
Website (When I have time) : http://www.nodecentral.co.uk
Re: Splunk - Log analyser
I would also like to see a splunk qpkg. I have a tvs-463 so I can run a vm with splunk but would prefer not to have the overhead of a VM
- QNAP_Stephane
I made a QPKG (free version) but bugging, not still understand why
after credential (admin/changeme)... i have web error error 505
i will try to debug, but cant promise
- Trexx
Another option might be looking to see if there is an LXC or Docker package for it that could be run in the new Container Station.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- QNAP_Stephane
got a start of answer why i bugs, seems some ports are used internally on QnapQNAP_Stephane wrote:I made a QPKG (free version) but bugging, not still understand why
Splunk listen on ports 8000, 8089, 9997, 8080 and 514 by default...
I guess the port cannot be bind because already in use
- parkerc
- Easy as a breeze
Hi, was any progress made on getting Splunk to run on QNAP?
Is there anything I can do to help?
- parkerc
- Easy as a breeze
I'm not too familiar with Docker, did you find that a straight forward thing to set up via Container Station?
anyone managed to run splunk on container station successfully?
I cannot get the image (https://hub.docker.com/r/splunk/splunk) to start...
I'll appreciate any advice.
