exif tool(post optware)
I can't manage to compile exif-tool from source and would appreciate either working instructions or a qpkg!
Re: exif tool(post optware)
exif tool is a perl application. Entware has package (ipk) with exif tool.
The package name to install is - perl-image-exiftool
Instructions to install entware are here - http://forum.qnap.com/viewtopic.php?f=351&t=116737
- Been there, done that
No need to compile it anymore then?
Qnap TS-253Pro 16Gb RAM - Single Storage Pool: 2 WRed 4TB (RAID 1)
Qnap TS-453A 16Gb RAM - Single Storage Pool: 4 WRed 4TB (RAID 5)
Thank you. Will try that.
I looked at a package list I found on the interweb with no luck, but perhaps not all entware are identical or I found an old list.
This works (just did it):
[~]# opkg install perl-image-exiftool
Just dropped by to say that after WAYYY longer than I'd like to admit mucking around with various Docker solutions ....
This was still the 20 second solution I was looking for.
So... you know... 'hello' from a half decade away.
- OneCD
