Homebridge
Homebridge
Homebridge is a lightweight NodeJS server you can run on your home network that emulates the iOS HomeKit API. It supports Plugins, which are community-contributed modules that provide a basic bridge from HomeKit to various 3rd-party APIs provided by manufacturers of "smart home" devices.
Since Siri supports devices added through HomeKit, this means that with Homebridge you can ask Siri to control devices that don't have any support for HomeKit at all.
https://github.com/nfarina/homebridge
Model: TVS-463
Firmware: QTS 4.3.3.0154
Storage: RAID 5, 4 x4TB HGST Deskstar HG0S03664
RAM: Crucial 16GB Kit (8GBx2) DDR3-1600 MT/s (PC3-12800)
Networking: Port trunking balance-tlb
Re: Homebridge
You could use Container Station and build / run it as a docker container:
https://github.com/patrickbusch/homebridge-docker
regards
regards
TS-251 - QTS 4.3.3.0210 build 20170606
Re: Homebridge
Hi, hope you're well, I am hoping you can help as I'm struggling here slightly.
I'm trying to set homebridge up as a docker to control my Vera automation system.
I have installed docker images from various users but basically struggle to know where the image actually sites. How can I tell where I am to place the configure.jason files as it's not immediately obvious as after creating a shortcut to /root/.homebridge it would appear there is no data there and when placing the config files in there they seem to be ignored. Any help or assistance is greatly appreciated.
Thanks in advance
Thanks in advance
Re: Homebridge
I haven't used the docker images with qnap. I've it installed on a raspberry pi. The config.json should be placed in /root/.homebridge like you did.
You have to place it there, there is no copy process
Re: Homebridge
Hi thanks for the response. I'm slightly confused by your comment about placing the file there. Am I to gather that /root/.homebridge isn't a physical location as I have created this physical directory ".homebridge" off /root/ I then have my config.jason file that I have edited appropriately in my xml editor and have no choice but to save it into this location using SSH.
Really stuck now and feel like I'm banging my head against a wall as this appears beyond my understanding which is frustrating.
Any direction or support you can offer is appreciated.
Thanks in advance
Thanks in advance
- Easy as a breeze
Re: Homebridge
Follow this guide (in French). This makes a lot of things easier
http://notkaa.xyz/notwiki/?page=Domotique
Re: Homebridge
I wish this was in English! Maybe Google Translate will help.trendchiller wrote:Follow this guide (in French). This makes a lot of things easier
Model: TVS-463
- Easy as a breeze
Homebridge
Google translator works quite well for this, I'm not as familiar with French, too
But this article also helped me a lot...
Re: Homebridge
I cannot make it work, anybody can help me. thks.
2/10/2017, 4:29:19 AM] Homebridge is running on port 58966.
Logged in as:
root
/root/.homebridge/.env not found.
Default env variables will be used.
Updating Homebridge.
/root/.homebridge/package.json not found.
/root/.homebridge/install.sh not found.
*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdn ... ceRegister>
[2/10/2017, 4:34:36 AM] No plugins found. See the README for information on installing plugins.
[2/10/2017, 4:34:36 AM] config.json (/root/.homebridge/config.json) not found.
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
[2/10/2017, 4:34:36 AM] Homebridge is running on port 51489.
Logged in as:
root
│ 031-45-154 │
Re: Homebridge
I think you can ignore those errors. Homebridge doesn't do much on its own, you need to install plugins to interact with your devices..
- Easy as a breeze
Re: Homebridge
Following the nice tutorial I managed to make it work.
I noticed one issue though: every time when NAS is restarted, HomeBridge stops working due to missing conf file. It seems that it tries to find the config.json in folder /root/.homebridge/. I tried to put the config file there but still get the same error.
Is it possible to make QNAP to run the startup command every time when the NAS is restarted? Thanks in advance!
- OneCD
Re: Homebridge
I know just the thing.somy1982 wrote:Is it possible to make QNAP to run the startup command every time when the NAS is restarted?
viewtopic.php?f=45&t=130345
- Easy as a breeze
Re: Homebridge
Cool, thanks! Will give a try and report back.OneCD wrote:I know just the thing.somy1982 wrote:Is it possible to make QNAP to run the startup command every time when the NAS is restarted?
Re: Homebridge
Did it work? What is the autorun doing?somy1982 wrote:Cool, thanks! Will give a try and report back.OneCD wrote:I know just the thing.somy1982 wrote:Is it possible to make QNAP to run the startup command every time when the NAS is restarted?
Re: Homebridge
Does this still work? Is there an updated app for this?
