[REQUEST] YouTube-DL
Ask community developers’ help for your most wanted Apps and also discover what the hottest and ultimate Apps are.
level42
Getting the hang of things
Contact:
Post by level42 »
YouTube-DL
Description:
youtube-dl is a command-line program to download videos from YouTube.com and a few more sites. It requires the Python interpreter, version 2.6, 2.7, or 3.2+, and it is not platform specific. It should work on your Unix box, on Windows or on Mac OS X. It is released to the public domain, which means you can modify it, redistribute it or use it however you like.
youtube-dl [OPTIONS] URL [URL...]
Link:
https://github.com/rg3/youtube-dl
Notes:
Albeit that we can install this ourselves, we are faced with a number of issues as this software has dependencies on specific locations to house its config files, such as /etc, /root, and /usr/local/bin. All of these directories are purged upon each reboot of the system.
This software is updated constantly! So, it would be nice to retain the ability to use the "youtube-dl -U" command to preform updates to the software.
NAS: TS-870-Pro | F/W: 4.3.4.0435
NAS: TS-859-Pro+ | F/W: 4.2.6
OneCD
Re: [REQUEST] YouTube-DL
Post by OneCD »
Just following up on some of these older app requests. ;)
youtube-dl is available via Entware:
opkg install youtube-dl
quassum
Know my way around
Post by quassum »
Almost to good to be true, installed perfectly fine via opkg but getting this error when trying to run:
# youtube-dl
Traceback (most recent call last):
  File "/opt/bin/youtube-dl", line 6, in <module>
    from pkg_resources import load_entry_point
  File "/opt/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3256, in <module>
    @_call_aside
  File "/opt/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3240, in _call_aside
    f(*args, **kwargs)
  File "/opt/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3269, in _initialize_master_working_set
    working_set = WorkingSet._build_master()
  File "/opt/lib/python3.7/site-packages/pkg_resources/__init__.py", line 582, in _build_master
    ws.require(__requires__)
  File "/opt/lib/python3.7/site-packages/pkg_resources/__init__.py", line 899, in require
    needed = self.resolve(parse_requirements(requirements))
  File "/opt/lib/python3.7/site-packages/pkg_resources/__init__.py", line 785, in resolve
    raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'youtube-dl==2020.7.28' distribution was not found and is required by the application
Moogle Stiltzkin
Contact:
Post by Moogle Stiltzkin »
quassum wrote: Wed Nov 11, 2020 5:35 pm ...
Check the arstechnica article link. basically they did a cease and desist order, and got youtube-dl removed. That is why you are getting
this reminds me of the streissand effect. people didn't realize this existed till they made it news headlines. now everyone downloads it to bypass those nasty youtube ads, kek
GitHub boots popular YouTube download tool after RIAA claim
RIAA claims tool, widely used by activists and archivists, is only for piracy.
https://arstechnica.com/tech-policy/202 ... iaa-claim/
i downloaded for my mpv video player from here, the last version
https://mpv.io/
https://www.videohelp.com/software/youtube-dl
NAS
Network
Resources
zyxmon
Experience counts
Contact:
Post by zyxmon »
quassum wrote: Wed Nov 11, 2020 5:35 pm Almost to good to be true, installed perfectly fine via opkg but getting this error when trying to run:
Cannot confirm
# opkg install youtube-dl
Installing youtube-dl (2020.7.28-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/youtube-dl_2020.7.28-1_aarch64-3.10.ipk
Installing python3-base (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-base_3.8.5-2_aarch64-3.10.ipk
Installing libtirpc (1.2.6-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libtirpc_1.2.6-2_aarch64-3.10.ipk
Installing python3-light (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-light_3.8.5-2_aarch64-3.10.ipk
Installing python3-unittest (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-unittest_3.8.5-2_aarch64-3.10.ipk
Installing libncurses (6.2-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libncurses_6.2-1_aarch64-3.10.ipk
Installing python3-ncurses (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-ncurses_3.8.5-2_aarch64-3.10.ipk
Installing python3-ctypes (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-ctypes_3.8.5-2_aarch64-3.10.ipk
Installing python3-pydoc (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-pydoc_3.8.5-2_aarch64-3.10.ipk
Installing python3-multiprocessing (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-multiprocessing_3.8.5-2_aarch64-3.10.ipk
Installing python3-codecs (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-codecs_3.8.5-2_aarch64-3.10.ipk
Installing libgdbm (1.18.1-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libgdbm_1.18.1-2_aarch64-3.10.ipk
Installing python3-gdbm (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-gdbm_3.8.5-2_aarch64-3.10.ipk
Installing python3-email (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-email_3.8.5-2_aarch64-3.10.ipk
Installing python3-urllib (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-urllib_3.8.5-2_aarch64-3.10.ipk
Installing libexpat (2.2.9-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libexpat_2.2.9-2_aarch64-3.10.ipk
Installing python3-xml (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-xml_3.8.5-2_aarch64-3.10.ipk
Installing libsqlite3 (3330000-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libsqlite3_3330000-1_aarch64-3.10.ipk
Installing python3-sqlite3 (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-sqlite3_3.8.5-2_aarch64-3.10.ipk
Installing python3-logging (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-logging_3.8.5-2_aarch64-3.10.ipk
Installing python3-distutils (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-distutils_3.8.5-2_aarch64-3.10.ipk
Installing python3-openssl (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-openssl_3.8.5-2_aarch64-3.10.ipk
Installing python3-cgi (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-cgi_3.8.5-2_aarch64-3.10.ipk
Installing python3-cgitb (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-cgitb_3.8.5-2_aarch64-3.10.ipk
Installing libxml2 (2.9.10-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libxml2_2.9.10-1_aarch64-3.10.ipk
Installing libdb47 (4.7.25.4.NC-5) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libdb47_4.7.25.4.NC-5_aarch64-3.10.ipk
Installing python3-dbm (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-dbm_3.8.5-2_aarch64-3.10.ipk
Installing python3-asyncio (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-asyncio_3.8.5-2_aarch64-3.10.ipk
Installing python3-lzma (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-lzma_3.8.5-2_aarch64-3.10.ipk
Installing python3-decimal (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-decimal_3.8.5-2_aarch64-3.10.ipk
Installing python3 (3.8.5-2) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3_3.8.5-2_aarch64-3.10.ipk
Installing python3-pkg-resources (47.1.0-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-pkg-resources_47.1.0-1_aarch64-3.10.ipk
Installing python3-setuptools (47.1.0-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/python3-setuptools_47.1.0-1_aarch64-3.10.ipk
Configuring python3-base.
Configuring libtirpc.
Configuring python3-light.
Configuring python3-email.
Configuring python3-urllib.
Configuring python3-pydoc.
Configuring python3-cgi.
Configuring python3-cgitb.
Configuring python3-decimal.
Configuring libexpat.
Configuring python3-xml.
Configuring python3-unittest.
Configuring libncurses.
Configuring python3-ncurses.
Configuring python3-ctypes.
Configuring python3-multiprocessing.
Configuring python3-codecs.
Configuring libgdbm.
Configuring python3-gdbm.
Configuring libsqlite3.
Configuring python3-sqlite3.
Configuring python3-logging.
Configuring python3-distutils.
Configuring python3-openssl.
Configuring libxml2.
Configuring libdb47.
Configuring python3-dbm.
Configuring python3-asyncio.
Configuring python3-lzma.
Configuring python3.
Configuring python3-pkg-resources.
Configuring python3-setuptools.
Configuring youtube-dl.
/share/CACHEDEV1_DATA/.qpkg/Entware/root # youtube-dl https://www.youtube.com/watch?v=f4_x_8tj18o
[youtube] f4_x_8tj18o: Downloading webpage
WARNING: Requested formats are incompatible for merge and will be merged into mkv.
[download] Destination: QNAP Hybrid Backup Sync HBS3 _ Decryption Guide-f4_x_8tj18o.f137.mp4
[download] 100% of 26.79MiB in 00:04
[download] Destination: QNAP Hybrid Backup Sync HBS3 _ Decryption Guide-f4_x_8tj18o.f251.webm
[download] 100% of 3.17MiB in 00:00
[ffmpeg] Merging formats into "QNAP Hybrid Backup Sync HBS3 _ Decryption Guide-f4_x_8tj18o.mkv"
Deleting original file QNAP Hybrid Backup Sync HBS3 _ Decryption Guide-f4_x_8tj18o.f137.mp4 (pass -k to keep)
Deleting original file QNAP Hybrid Backup Sync HBS3 _ Decryption Guide-f4_x_8tj18o.f251.webm (pass -k to keep)
quassum
Know my way around
Post by quassum »
Looks like I'm running Python 3.7 while you're on 3.8 I'm using the one installed by sherpa at the moment, not sure whether that's easy to update?
Moogle Stiltzkin
Contact:
there's not gonna be another update for youtube-dl. they got shutdown.
i'm not aware of anyone that is taking over that project (most likely not). but you can still get the youtube-dl component that was last updated and use that at least for now.
not sure about qnap, but for mpv on desktop when the update script couldn't grab the youtube-dl component, i just manually copy pasted the last latest of that file, and it worked :}
so i assume you would have to do something similar if it can't grab the file from the repo for youtube-dl
NAS
Network
Resources
quassum
Know my way around
Post by quassum »
Moogle Stiltzkin wrote: Thu Nov 12, 2020 12:06 am there's not gonna be another update for youtube-dl. they got shutdown.
Do you have a source for that? Only their Github repository got shut down as far as I'm aware. Their site https://youtube-dl.org is still up and they also released a new version after the takedown. This is the changelog:
version 2020.11.01
Core
* [utils] Don't attempt to coerce JS strings to numbers in js_to_json (#26851)
* [downloader/http] Properly handle missing message in SSLError (#26646)
* [downloader/http] Fix access to not yet opened stream in retry
Extractors
* [youtube] Fix JS player URL extraction
* [ytsearch] Fix extraction (#26920)
* [afreecatv] Fix typo (#26970)
* [23video] Relax URL regular expression (#26870)
+ [ustream] Add support for video.ibm.com (#26894)
* [iqiyi] Fix typo (#26884)
+ [expressen] Add support for di.se (#26670)
* [iprima] Improve video id extraction (#26507, #26494)
Moogle Stiltzkin
Contact:
did u check the arstechnica link i asked u to look at? thats where i found out about this. i was using a different app on windows that has a script updating that uses youtube-dl when i noticed that error message you posted. the reason i found out for that, because their project got shutdown so it couldn't pull the youtube-dl from the original host.
so i worked around that by downloading from an archive site, the last latest file for it, then copy into the app folder, then it worked :)
NAS
Network
Resources
quassum
Know my way around
Post by quassum »
Moogle Stiltzkin wrote: Thu Nov 12, 2020 12:16 am did u check the arstechnica link i asked u to look at?
Yup, nowhere in the article it’s mentioned the project will shutdown.
OneCD
Post by OneCD »
quassum wrote: Wed Nov 11, 2020 11:43 pm Looks like I'm running Python 3.7 while you're on 3.8 I'm using the one installed by sherpa at the moment, not sure whether that's easy to update?
Python 3.7 was previously required if you're running Watcher3, as it won't yet run on Python 3.8. Is OWatcher3 installed?
quassum
Know my way around
Post by quassum »
OneCD wrote: Thu Nov 12, 2020 1:43 am Python 3.7 was previously required if you're running Watcher3, as it won't yet run on Python 3.8. Is OWatcher3 installed?
Ah good catch, it is indeed installed here. Looks like it's still not supported https://github.com/barbequesauce/Watcher3/issues/79 maybe time to switch to something else.
OneCD
Post by OneCD »
Maybe try Stephane's Watcher3 QPKG? https://qnapclub.eu/en/qpkg/471
I think he packages it with a specific version of Python.
After you've transferred across your settings, uninstall OWatcher3, then reinstall Entware to ensure the latest Python 3 is installed:
sherpa reinstall ew
jaysona
Been there, done that
Post by jaysona »
Moogle Stiltzkin wrote: Thu Nov 12, 2020 12:16 am did u check the arstechnica link i asked u to look at? thats where i found out about this. i was using a different app on windows that has a script updating that uses youtube-dl when i noticed that error message you posted. the reason i found out for that, because their project got shutdown so it couldn't pull the youtube-dl from the original host.
You need to understand the difference between a git repository being pulled and a project shutting down. Youtube-dl was never "shut down" and probably never will be, just as Anonymous can never be shut down.
RAID is not a Back-up!
H/W: TS-219 Pro / TS-509 Pro
quassum
Know my way around
Post by quassum »
Return to “Apps Wanted”
