[Request] BOINC QPKG
- Don
I am requesting a QPKG of BOINC be built.
The Berkeley Open Infrastructure for Network Computing is an open-source middleware system that supports volunteer and grid computing. Originally developed to support the SETI@home project, it became generalized as a platform for other distributed applications in areas as diverse as mathematics, linguistics, medicine, molecular biology, climatology, environmental science, and astrophysics, among others. BOINC aims to enable researchers to tap into the enormous processing resources of multiple personal computers around the world.
What a great way to contribute to scientific research by using your idle time on your NAS. You can select what projects you contribute to and how much resources it will use. I am running it on a Windows 2012 server and a Windows 10 Surface Pro and it does not slow them down at all. There is a Linux version available and it would be great if we could get a QPKG so we could run it. I know my QNAPs sit idle most of the time and if I can put those idle cycles to good use why not.
Main page --> http://boinc.berkeley.edu/
Software can be downloaded from here --> https://boinc.berkeley.edu/download_all.php
Project list --> https://boinc.berkeley.edu/projects.php
- Toxic17
Re: [Request] BOINC QPKG
Perhaps QNAP Stephane could compile one if he had some free time?
Sent from my ONEPLUS A3003 using Tapatalk
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
- Don
That is what I am hoping.
I use Seti@Home + later BOINC since 1999
But back in the days the energy saving protocols and tricks used by the CPU manufactures were not as advanced as they are today. CPU are not realy wasting "idle cycles" anymore.
CPU's clock down or (shut certain cores off entirely) when not in use. That in turn lowers the power needed and heat generated. So running BOINC will increase energy your costs and noise of your NAS.
- Don
Yeah I did Seti@home years ago also.
This is true. What I meant by idle cycles was times when the CPU(s) had low utilization. Yes BOINC will increase utilization but you can configure how many CPUs it uses and to what percentage also. So you can control how much power Is needed and how much heat is generated.
not much .. but a little bragging right (SETI@home is only one of several BOINC projects I am attached to right now)
- Don
Nice. I'm attached to Seti and a few others also.
Any idea how to contact Stephane?
- Don
Stephane are you out there?
Anyone know how to contact him?
- Toxic17
Don, best if goto https://www.forum-nas.fr/viewforum.php?f=21 and ask there. (English will do)
QoolBox is his alias.
Regards Simon
Qnap Downloads
Qnap Downloads
- Don
Thanks Simon.
- Don
Thanks. Would it be bettter to run it in a Ubuntu VM?
- QNAP_Stephane
FYI
I have 7.7.0 version from git compiled and running
i am able to propose the qpkg in short time, but will be in CLI...
i dont think boinc manager is necessary neither x11 to run it... but may be i am wrong... never used this kind of software
but from wiki boinccmd is enought
http://boinc.berkeley.edu/wiki/Controll ... C_remotely
./boinc_client --help
The command-line options for ./boinc_client are intended for debugging.
The recommended command-line interface is a separate program,'boinccmd'.
Run boinccmd in the same directory as ./boinc_client.
Usage: ./boinc_client [options]
--abort_jobs_on_exit when client exits, abort and report jobs
--allow_remote_gui_rpc allow remote GUI RPC connections
--allow_multiple_clients allow >1 instances per host
--attach_project <URL> <key> attach to a project
--check_all_logins for idle detection, check remote logins too
--daemon run as daemon (Unix)
--detach_console detach from console (Windows)
--detach_project <URL> detach from a project
--dir <path> use given dir as BOINC home
--exit_after_app_start N exit N seconds after an app starts
--exit_after_finish exit right after finishing a job
--exit_before_start exit right before starting a job
--exit_before_upload exit right before starting an upload
--exit_when_idle exit when there are no results
--fetch_minimal_work fetch only 1 job per device
--file_xfer_giveup_period N give up on file xfers after N sec
--gui_rpc_port <port> port for GUI RPCs
--gui_rpc_unix_domain use Unix domain for GUI RPCs
--help show options
--insecure disable app sandboxing (Unix)
--master_fetch_interval N limiting period of master retry
--master_fetch_period N reload master URL after N RPC failures
--master_fetch_retry_cap N exponential backoff limit
--no_gpus don't check for GPUs
--no_gui_rpc don't allow GUI RPC, don't make socket
--no_info_fetch don't fetch project list or client version info
--no_priority_change run apps at same priority as client
--pers_giveup N giveup time for persistent file xfer
--pers_retry_delay_max N max for file xfer exponential backoff
--pers_retry_delay_min N min for file xfer exponential backoff
--redirectio redirect stdout and stderr to log files
--reset_project <URL> reset (clear) a project
--retry_cap N exponential backoff limit
--run_cpu_benchmarks run the CPU benchmarks
--run_by_updater set by updater
--sched_retry_delay_max N max for RPC exponential backoff
--sched_retry_delay_min N min for RPC exponential backoff
--show_projects show attached projects
--skip_cpu_benchmarks don't run CPU benchmarks
--start_delay X delay starting apps for X secs
--suppress_net_info don't send network addrs to server
--unsigned_apps_ok allow unsigned apps (for testing)
--update_prefs <URL> contact a project to update preferences
--version show version info
./boinccmd --help
usage: boinccmd [--host hostname] [--passwd passwd] [--unix_domain] command
default hostname: localhost
default password: contents of gui_rpc_auth.cfg
Commands:
--client_version show client version
--create_account URL email passwd name
--file_transfer URL filename op file transfer operation
op = retry | abort
--get_app_config URL show app config for given project
--get_cc_status
--get_daily_xfer_history show network traffic history
--get_disk_usage show disk usage
--get_file_transfers show file transfers
--get_host_info
--get_message_count show largest message seqno
--get_messages [ seqno ] show messages > seqno
--get_notices [ seqno ] show notices > seqno
--get_project_config URL
--get_project_status show status of all attached projects
--get_proxy_settings
--get_simple_gui_info show status of projects and active tasks
--get_state show entire state
--get_tasks show tasks
--get_old_tasks show reported tasks from last 24 hours
--join_acct_mgr URL name passwd attach account manager
--lookup_account URL email passwd
--network_available retry deferred network communication
--project URL op project operation
op = reset | detach | update | suspend | resume | nomorework | allowmorework | detach_when_done | dont_detach_when_done
--project_attach URL auth attach to project
--quit tell client to exit
--quit_acct_mgr quit current account manager
--read_cc_config
--read_global_prefs_override
--run_benchmarks
--set_gpu_mode mode duration set GPU run mode for given duration
mode = always | auto | never
--set_host_info product_name
--set_network_mode mode duration set network mode for given duration
--set_proxy_settings
--set_run_mode mode duration set run mode for given duration
--task url task_name op task operation
op = suspend | resume | abort
- Don
Nice!!
Can't it be managed via a manager running on another system (Windows PC)?
- QNAP_Stephane
I guess it is possible but need read docs...
- Don
Just an FYI that the BIONC manager does let you control BIONC running on other systems.
