Is there any possibility of create a package for Livestreamer or Streamlinks?
Livestreamer: https://github.com/chrippa/livestreamer
Streamlinks: https://github.com/streamlink/streamlink
I´ve tried to manually install streamlinks in the qnap following the steps in the github page but I have this errors:
Traceback (most recent call last):
File "/share/CACHEDEV1_DATA/.qpkg/QPython2/bin/streamlink", line 6, in <module>
from pkg_resources import load_entry_point
File "/share/CACHEDEV1_DATA/.qpkg/QPython2/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3019, in <module>
@_call_aside
File "/share/CACHEDEV1_DATA/.qpkg/QPython2/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3003, in _call_aside
f(*args, **kwargs)
File "/share/CACHEDEV1_DATA/.qpkg/QPython2/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3032, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/share/CACHEDEV1_DATA/.qpkg/QPython2/lib/python2.7/site-packages/pkg_resources/__init__.py", line 655, in _build_master
ws.require(__requires__)
File "/share/CACHEDEV1_DATA/.qpkg/QPython2/lib/python2.7/site-packages/pkg_resources/__init__.py", line 963, in require
needed = self.resolve(parse_requirements(requirements))
File "/share/CACHEDEV1_DATA/.qpkg/QPython2/lib/python2.7/site-packages/pkg_resources/__init__.py", line 849, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'pycryptodome<4,>=3.4.3' distribution was not found and is required by streamlink
Keep waiting your comments.
Thank you and best regards.
