In my windows/linux LAN some machines can write to the NAS and others prefer to write to my Windows server. With my WDMyCloud I had a replication process running using Allwaysynch that kept shares in synch between the Windows server shares and their replicas on the WD. This was a bi-directional update process that could propagate deletions if I so chose. I had been hoping that the Hybred Backup replication would provide an equivalent functionality. But I see that if I want to replicate between a share on the QNAP and a share on the Windows 2012r2 server my only choice is one way... so one has to be the master always and the other merely a backup copy.
Be real nice if two way replication were available within the QNAP NAS.
greg latiak
Hybred Backup RTRR two way replication to CIFS
Re: Hybred Backup RTRR two way replication to CIFS
Two-way sync is only supported with Qnap-proprietary RTRR protocol so only possible Qnap-to-Qnap.
