Hi all,
Have been using Acronis Mobile for my phone and it works great! (On a TS-453Be)
Now, I have another QNAP TS-228A with realtek. This device does not support Acronis Mobile.
Is there any other QNAP package that does the same as Acronis Mobile? (I do NOT want to setup some cloud-based solution to backup my mobile device to the cloud)
Any help is appreciated.
Similar app as acronis backup for smartphone and qnap
Re: Similar app as acronis backup for smartphone and qnap
cloud backups to cloud services work from anywhere..that is a plus
qnap backups only work at home ..unless you are exposing the nas to the world (bad idea) or do backups via vpn (cumbersome)
