Dear all
I'm trying to use the Azure app to make a Cloud Backup of a TP-469L QNAP NAS.
Everything is working very well, apart from the bandwidth limitation option on the account configuration.
If I put a limit to the upload bandwith based on times (i.e. from 7 to 20) it seems that the limit is applied all day, no matter the hours I put in the configuration.
time on the NAS is synchronized with NTP and is correct...
Anyone else is experiencing such behaviour?
Azure Storage QPKG band limit
Re: Azure Storage QPKG band limit
I have the same issues. The limit is applied all day, no matter what range I put in.
