Good evening QNAP Community
I am looking for assistance, hints and tipps in regard of using AZUR Cloud Service on QNAP TS-469Pro as BackUp system. Do someone of the ommunity can let me have good advises, Hints and Tipps to this topic. Which AZUR Service is the most useful for QNAP BackUp. Can someone help me to implement the AZUR BackUp service on my QNAP TS-469Pro.
Thanks and best regards. Good start into the new week.
Gregor
AZUR Cloud Service for QNAP TS-469Pro
- barrie.elliott
Re: AZUR Cloud Service for QNAP TS-469Pro
Hi, simply put the QNAP will support "Azure Storage Accounts" not "Backup Vaults" which is what used by Azure Backup that's installed on Server system.
Simply Login to your Azure account and go to "Data Services" -> "Storage" -> the create a storage account with a URL name that's unique.
Select the location to store the file storage account and replication type if any at all.
Once created you have to then get the keys by clicking on the storage account and managed access keys, then use these in the Azure QPKG on the QNAP.
Its relatively simple, but if its your first time i would just pace yourself and if all goes to plan, may take just 5 minutes to setup.
Regards
Barrie Elliott
IT Solutions Specialist
Barrie Elliott
