I have installed azure backup app in tvs-1271U-rp. I had worked fine in the beginning. Then it keeps "failed because of failing to access local metadata, please check your disk status (space and inode) and try again".
I noticed that if backup job succeeds, there is a metadata file *.tar.gz generated in the Azure container. But new backup jobs have never generated that *.tar.gz metadata file.
I have tried many different ways including re-creating backup jobs, reboot tvs machine, created new azure container, etc, and cannot make a backup job works again.
Please help.
Failling to access to local metadata by using azure abckup app in tvs-1271U-RP
Re: Failling to access to local metadata by using azure abckup app in tvs-1271U-RP
Above problem may be solved by changing firewall settings in azure, but further questions:
1) can we manual create/edit metadata file? Is the metadata file necessary?
2) why it takes several hours in the "scanning" stage of a backup job? Backup is too slow.
