[App] OpenStack Swift v1.0.350
QNAPJason
QNAP Staff
Post by QNAPJason » Tue May 06, 2014 9:22 pm
[Version]
OpenStackSwift v1.0.350
[Change Log]
1. Support both manual and scheduled backup
2. Support full and incremental backup
3. Support flexible file filtering using type, date, and size
4. Support SSL transfer encryption and client-side AES-256 encryption
5. Support multiple cloud account management
6. Support dashboard and job statistics
7. Support configurable network error recovery options
8. Support job activity logging for tracing history
9. Support multi-threaded data transfer (excluding WebDAV) in one job
10. Support concurrent job execution
11. Support restore directly from the cloud for disaster recovery scenario
12. S3 Plus App supports S3-compatible public and private cloud storage
13. OpenStack Swift App offers built-in support for RackSpace and HP Cloud.
14. Azure Storage App supports both global and China site
# For OpenStack Swift app, you can specify the server as your backup destination. However, there could be compatibility risks. Please conduct testing or conduct QNAP before you start backing up more data.
# OpenStack Swift App does NOT support cloud storage that cannot use multi-byte characters as object names.
[Download]
Note: Please right-click the URL to save the file if you cannot download it directly.
ARM NAS
x86 NAS
JCCHAP
Re: [App] OpenStack Swift v1.0.350
Post by JCCHAP » Thu May 08, 2014 6:31 pm
recherche une intégration de HUBIC sur QNAP
TS 219P version 3.8.1
schumaku
Contact:
Post by schumaku » Thu May 08, 2014 10:42 pm
Salut,
JCCHAP wrote:recherche une intégration de HUBIC sur QNAP
Unless somehting has changed recently: While HubiC does make use of OpenStack Swift, they have implemented their own authentication scheme, so i'ts not as easy as 1-2-3 to configure the OpenStack Swift QPKG to HubiC. Have no time to look into the API and a service that need to be hosted somewhere (not sure yet the local NAS would do) - but will have a chat with QNAP tomorrow.
-Kurt.
AlvinJones
First post
Post by AlvinJones » Sat Jun 28, 2014 11:39 am
Hi
The links for this application are down are you able to re-upload this or provide a new link?
Thanks!
mardianto
Post by mardianto » Mon Jun 30, 2014 11:36 am
hi,
please go to this link: viewtopic.php?f=325&t=94699
QNAP staff
Return to “OpenStack Swift”
