hi, How i can delete vault from glacier app in qnap? i lost my secret and this app is only place where is saved.
thx
Glacier vault deletion from qnap glacier app
- selfish
Qnap TS - 431 qts 4.2.0 build 20150716
Re: Glacier vault deletion from qnap glacier app
You have to use a third party tool.
I have recently used the following tool: http://www.cloudberrylab.com/amazon-glacier-client.aspx
Last year I have used an open source tool that requires a bit more fiddling around: https://github.com/leeroybrun/glacier-vault-remove
I found the first one the easiest to use.
Cheers,
TVS EC880 / 8 x 6TB WD Red in Raid 6 / QTS 4.5.4.1800
Hybrid Backup Station 3 / Virtualization Station / Container Station / QSync
TS-509 Pro / 4 x 2TB Seagate in Raid 5 / QTS 4.2.X (latest build)
Just curious: why not simply generate a new security key for this user from within the AWS console?selfish wrote:hi, How i can delete vault from glacier app in qnap? i lost my secret and this app is only place where is saved.
thx
I've used the Freeze app for macOS to empty vaults before deleting them.
Note that if you generate a new security key for the AWS IAM user, I think the Glacier app from QNAP will not let you use an existing vault, and will instead require that you back up to a new vault. This caught me by surprise and is less than ideal.
