A backup system is only helpful if one can restore successfully, however, so I've been trying to test that. I'm using on OS X app called Freeze to download the inventory and then the files that make up the sparsebundle. I know I need to then decrypt the files using:
openssl enc -d -aes-256-cbc -k %password% -in %encrypted_file% -out %decrypted_file%
bad decrypt
39428:error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt:/BuildRoot/Library/Caches/com.apple.xbs/Sources/OpenSSL098/OpenSSL098-59.40.2/src/crypto/evp/evp_enc.c:330:
- What does the bad decrypt error mean in the first attempt?
- Is it possible to inspect the password the Glacier app is using to encrypt the files? I have full access to the NAS, and presumably it has the password saved somewhere since it's using it to encrypt the files. Perhaps I did record the wrong password, or perhaps the password I chose was too long (at 32 characters), or some of the special characters were not saved properly.
- Anything else I should try? Otherwise I might just give up on client side encryption and rely instead on encryption of the sparsebundle disk images themselves.
