"message":"",
"error_code":0,
"result":{
"is_acl_xattr":false,
"maximum_skipped_files":10,
"is_compress":false,
"limit_file_size_max":"",
"source_folder_list":[
"/REMOVED FOR SECURITY REASONS"
"job_type":"backup",
"encrypt_algorithm":"aes-256-cbc",
"is_related_running":false,
"timeout_in_second":60,
"compression_file_size":"4kb",
"maximum_rate":0,
"id":"1",
"compression_ratio":9,
"limit_file_type_filter":[
"others",
"temporary"
"is_ignore_symbolic_links":false,
"display_name":"REMOVED FOR SECURITY REASONS",
"encrypt_password":"REMOVED FOR SECURITY REASONS@le_type_filter_others": [ ".db", ".dll" ], "is_running": false, "concurrent_connections": 5, "is_backup_only_updated_files": true, "limit_file_date_from": "", "is_delete_extra_files": false, "retry_interval_in_second": 180
SyntaxError: JSON.parse: expected ',' or '}' after property value in object at line 26 column
