I've just upgraded my QNAP TS-569 Pro to 4.2.4 Firmware. I have Glacier app at version 1.1.330. After running the Glacier App after the upgrade, all the configuration ( including the AWS account and jobs definitions) is gone.
I've generated the debug report and looking inside I do see my original jobs configuration (in Glacier\cloudconnector.admin.conf.dump) - however the application itself doesn't show it.
Anybody knows how to fix this problem and restore all Glacier jobs ? Or do I need to re-create the account and jobs from scratch (which is a pain) ?
Vlad
After upgrading QNAP FM to 4.2.4 Glacier App lost its config
Re: After upgrading QNAP FM to 4.2.4 Glacier App lost its config
Unfortunately I don't know how to fix the problem and restore all Glacier jobs, but I just want to mention that, based on my experience, if you end up having to recreate the jobs, you will also have to select new vaults.
This was a problem for me since I had a lot of data and didn't want to pay the costs from duplicating it. I think Glacier Backup to Existing Vault is the central thread about the issue.
This is what I see in the logs - seems as some configuration file error in Glacier python scripts:
Maybe someone from the Glacier developer team could take a look at it ?
Vlad
2017-03-17 23:57:11,160 PID:12854 commandmgr.py:146 cc ERROR ValueError= { "cmd": "list_jobs", "job_type": "backup", "REMOTE_ADDR": "$\u00157÷àEêö\u0002" }
Traceback (most recent call last):
File "./package/src/shared/bin/qnap/cgi/commandmgr.py", line 144, in __load_from_json_string
File "/share/MD0_DATA/.qpkg/Glacier/python/lib/python2.7/json/__init__.py", line 351, in loads
return cls(encoding=encoding, **kw).decode(s)
File "/share/MD0_DATA/.qpkg/Glacier/python/lib/python2.7/json/decoder.py", line 366, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/share/MD0_DATA/.qpkg/Glacier/python/lib/python2.7/json/decoder.py", line 382, in raw_decode
obj, end = self.scan_once(s, idx)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xf7 in position 1: invalid start byte
2017-03-17 23:57:11,163 PID:12854 cgid.py:79 cc ERROR Got an exception, try to rebind
File "./package/src/shared/bin/qnap/daemon/cgid.py", line 72, in __execute_cmd
File "./package/src/shared/bin/qnap/cgi/commandmgr.py", line 232, in load_command_from_str
File "./package/src/shared/bin/qnap/cgi/commandmgr.py", line 204, in __parse_cgi_parameters
KeyError: 'cmd'
Vlad
Upgrading the Glacier App to 1.1.413 seems to resolve the issue.
