Glacier BKP Long files name error
benzarod
Post by benzarod » Wed Sep 25, 2019 8:47 pm
I have setup a bkp from qnap to Glacier .
I noticed the following error ¨you don't have permissions to access this file, check access permissions"
I checked the SOURCE permissions and didn´t see issues. So I decided to move the entire folder who is showing the error to another folder to isolate the issue and I noticed that the error is a LONG FILE NAME (possible with spaces). I have many cases who will do a fail backup.
Is there any way to workaround the issue ? (look Attach)
Thanks Rod
storageman
Ask me anything
Re: Glacier BKP Long files name error
Post by storageman » Wed Sep 25, 2019 9:07 pm
If you can't correct the filenames perhaps you could zip them before replicating.
Return to “Amazon Glacier”
