BUG: "statistics" SQLLite file is not handled appropriately. The core issue is that any change to the job, deletes any statistics thus losing history/state of the existing job.
Steps to recreate:
1. I created an S3 backup and it worked successfully.
2. It ran automatically after a few hours (2nd run) -- successfully.
3. I made a small change to the backup job by adding more folders to back. MISTAKE.
4. BUG: Entries from the statistics SQLLite3 database (/share/CACHEDEV1_DATA/.qpkg/CloudBackupSync/data/0/statistics) were DELETED.
5. When I try to run job again, is_job_executed is FALSE because there are no entries with job_id=1
This is crazy because I should be allowed to change the job settings as needed without requiring a new job.
How I figured it out:
The log ( tail -f /share/CACHEDEV1_DATA/.qpkg/CloudBackupSync/log/0/1/cloudconnector-debug.log) said the following on the failing job:
[2017-01-17 20:33:00,712][JOB:1][PID:2531][TNAME:MainThread][INFO ][cc][engine.py:main_function:179] : Photos and Video to S3-IA, Go!
[2017-01-17 20:33:01,582][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][engine.py:process:260] : [b]test container exist, is_job_executed False[/b]
[2017-01-17 20:33:01,583][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][awss3connector.py:test_container:509] : test_container
[2017-01-17 20:33:01,584][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][awss3connector.py:get_connection:233] : establish connection with is_secure=True
[2017-01-17 20:33:01,585][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][awss3connector.py:__get_connection_host:207] : Connect S3...
[2017-01-17 20:33:01,589][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][awss3connector.py:__get_connection_by_bucket_region:410] : try to get bucket sidhant-nasbackup
[2017-01-17 20:33:01,589][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][awss3connector.py:__get_connection_by_bucket_region:412] : Finish get bucket
[2017-01-17 20:33:01,680][JOB:1][PID:2531][TNAME:MainThread][ERROR ][cc][awss3connector.py:__get_connection_by_bucket_region:423] : get_location
Traceback (most recent call last):
File "./package/src/shared/python-lib/connector/awss3connector.py", line 421, in __get_connection_by_bucket_region
File "./package/src/shared/python-lib/boto/s3/bucket.py", line 1146, in get_location
S3ResponseError: S3ResponseError: 400 Bad Request
AuthorizationHeaderMalformed[b]The authorization header is malformed; the region 'us-east-1' is wrong; expecting 'us-west-2'us-west-[/b]21954995DE6DAFB55eRYdR6fhp71QPLJPaCHiHLdyZmPWXYR64a5o9THeK0yBQAUl6bJCDoTHpI7ur+zlXYLjjAkCAdw=
[2017-01-17 20:33:01,682][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][awss3connector.py:get_connection:233] : establish connection with is_secure=True
[2017-01-17 20:33:01,683][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][awss3connector.py:__get_connection_host:207] : Connect S3...
[2017-01-17 20:33:01,686][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][cc][awss3connector.py:test_container:528] : Bucket exists already
[2017-01-17 20:33:01,920][JOB:1][PID:2531][TNAME:MainThread][ERROR ][cc][awss3connector.py:test_container:592] : get exception BackupDstFolderNotAvailable: (BackupDstFolderNotAvailable(...), -4005, 'the folder name is not available. Please select antoher one')
File "./package/src/shared/python-lib/connector/awss3connector.py", line 542, in test_container
[2017-01-17 20:33:01,921][JOB:1][PID:2531][TNAME:MainThread][ERROR ][cc][engine.py:process:282] : exist a container, but job was never ran
[2017-01-17 20:33:04,371][JOB:1][PID:2531][TNAME:MainThread][DEBUG ][qnap.qlog][qlog.py:emit:142] : log_tool: Appending a log to database...
Done. Return value is 0
[2017-01-17 20:33:04,651][JOB:1][PID:2531][TNAME:MainThread][ERROR ][cc][logutils.py:do_fail_log:293] : BackupDstFolderNotAvailable: the folder name is not available. Please select antoher one
[2017-01-17 20:33:04,663][JOB:1][PID:2531][TNAME:MainThread][INFO ][cc][engine.py::274] : end backup job:1
I first fixed the region issue. This can be fixed by editing /etc/config/cloudconnector/CloudBackupSync/cloudconnector.%system_shared%.conf and looking for the key "region_name". In my case, it was set to blank. This is again because the stupid code decided to re-init the entire job when I made a small edit. Setting it to 'us-west-2' or whatever your region is will fix this.
Step 2
Now, the process failed again, with a different error in logs. It said, "Bucket exists already".
Step 3
I looked into, why would it throw that error. Turns, out that the check on a bucket is made on the *first run*. How does it know or why does it think its the first run? Because the variable is_job_executed was set to False.
Step 4
How is the variable is_job_executed set?
It is set in engine.py in the share/CACHEDEV1_DATA/.qpkg/CloudBackupSync/bin directory. Thre, it calls the backupstatistics.py.
backupstatistics.py runs a SQL something like:
"SELECT COUNT(*) FROM backup_job WHERE job_id=XYZ and (number_of_files_to_process > 0 or size_transferred > 0 or state='Success' or state='Stopped')"
But where is the DB file? Its here (Ifigured this out by running some custom python code that calls same functions as QNAP code): /share/CACHEDEV1_DATA/.qpkg/CloudBackupSync/data/0/statistics0
When I looked at the DB in a SQL broswer, there were NO ENTRIES pertaining to job_id=1. I added a dummy entry:
INSERT INTO backup_job VALUES(1,1,'Success',NULL,'2017-01-17 20:11:00','2017-01-17 20:12:00',0,0,0,0,0,0,0,0,0,NULL,0);
It WORKED.
