Has anyone else experienced the failure of their S3 plus backups after updating to QTS version 4.3.3.0154?
I am getting the following error..
"Backup job [********->xxxx.xxxx] failed because the bucket name is not available (not empty). Please select another one."
I have 10 backups to S3, all with a similar error.
Two questions.
What did I do wrong or forget to do
Does this mean I'll need to start from the backups from begining and sync ALL the data again?
S3 Plus fails after update to 4.3.3.0154
Re: S3 Plus fails after update to 4.3.3.0154
Same problem here. Is there any solution?
Did either of you find a solution or workaround to this? I am now getting the same error and really don't want to have to recreate the buckets and backup almost 1TB from scratch!!
