We are using a QNAP TS-453A, connected via a single ethernet cable to a gigabit switch, on an internet connection with a 25mbps upload speed (periodically tested and quite reliably the case).
Whatever we do, we can't seem to get S3 Plus to upload at higher speeds than 1mbps. When I check the "recent transfer rate" in the job status it invariably tops out in the 95-100KBps range.
I checked the rate limit screen and there's no difference with it enabled or disabled. I can make it upload even slower by setting the rate limit to something like 10KBps, but I can't get it above 100KBps ever.
Our initial S3 Plus backup of 600GB has been running nonstop since May and it's only 25% done today (almost October).
During this time, I used rsync from the CLI of the very same QNAP NAS to copy the entire 600GB volume to a remote location and it took about 4 days start to finish.
I've also uploaded files directly to S3 using s3cmd from another machine in the same office (connected to the same switch) and got near full speed.
The facts: The NAS is not heavily loaded, it can send files within the office at close to 1gbps, the office internet connection can upload to S3 at 25mbps, and the NAS itself can upload across the internet at 25mbps. It just won't do it in S3 Plus.
Therefore, the bottleneck truly seems to be in the S3 Plus software.
What do do? The estimated completion time of the backup is well into 2018. That's not reasonable for data that I know for a fact can be transmitted in under four days. Do we abandon S3 plus or is there a solution that makes it usable?
S3 Plus slow: will not upload faster than 1mbps
- Toxic17
Re: S3 Plus slow: will not upload faster than 1mbps
have you tried replacing the LAN cable, just in case its is faulty? are there any crc errors listed on the LAN interface?
ssh into your NAS
type:
[~] # ifconfig
you should see an output, please post your findings. you can mask the IP if you want...
ssh into your NAS
type:
[~] # ifconfig
Regards Simon
Qnap Downloads
MyQNap.Org Repository
NAS: TS-673A QuTS hero h5.1.6.25734 • TS-121 4.3.3.2420 • APC Back-UPS ES 850G2
Network: VM Hub3: 500/50 • UniFi UDM Pro: 3.2.12 • UniFi Network Controller: 8.1.127
USW-Aggregation: 7.0.50 • US-16-150W: 7.0.50 • US-8-60W: 7.0.50 • 2x USW Mini Flex 2.0.0 • UniFi AC Pro 6.6.69 • UniFi U6-LR 6.6.69
UniFi Protect: 3.0.26/8TB Skyhawk AI • 3x G3 Instants: 4.70.39 • UniFi G3 Flex: 4.70.39 • UniFi G5 Flex: 4.70.39
Qnap Downloads
- Toxic17
Also
[~] # ethtool eth0
[~] # ethtool eth1
[~] # ethtool eth0
[~] # ethtool eth1
Regards Simon
Qnap Downloads
Qnap Downloads
I don't think it's the cable, as I was able to rsync the entire contents of the volume in one go without delays - four days of sustained traffic. It's on a new 1m cat6 cable directly to the switch. And we do not observe any day-to-day slowdowns with local access (via SMB). Before posting I tried again and had no trouble saturating the external link with scp copies in both directions between the NAS and a remote server. Meanwhile S3 Plus keeps doddering along at 95KBps.
ifconfig:
ethtool (eth0 only; we don't have anything plugged into eth1):
ifconfig:
bond0 Link encap:Ethernet HWaddr 32:F2:51:XX:XX:XX
UP BROADCAST NOTRAILERS MASTER MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr 00:08:9B:XX:XX:XX
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
RX packets:639354151 errors:0 dropped:4 overruns:3930 frame:0
TX packets:926036471 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:241318056788 (224.7 GiB) TX bytes:1099732219848 (1.0 TiB)
Memory:81800000-8187ffff
eth1 Link encap:Ethernet HWaddr 00:08:9B:XX:XX:XX
UP BROADCAST MULTICAST MTU:1500 Metric:1
Memory:81900000-8197ffff
eth2 Link encap:Ethernet HWaddr 00:08:9B:XX:XX:XX
Memory:81600000-8167ffff
eth3 Link encap:Ethernet HWaddr 00:08:9B:XX:XX:XX
Memory:81700000-8177ffff
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:8570173 errors:0 dropped:0 overruns:0 frame:0
TX packets:8570173 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4496764966 (4.1 GiB) TX bytes:4496764966 (4.1 GiB)
Settings for eth0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: off (auto)
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
- Toxic17
looks good, any VPN's to the NAS, just wondering if the data to s3 is being routed another way.
try a traceroute on your NAS to the s3 servers
Regards Simon
Qnap Downloads
Qnap Downloads
Nope, no VPN, it goes straight through. Here's a traceroute from the NAS, it looks about the same as if I do it from a desktop on the same office network:
Pings are sweet and steady at 10ms; I let it go for five minutes and got zero lost packets.
# traceroute 52.216.81.112
traceroute to 52.216.81.112 (52.216.81.112), 30 hops max, 46 byte packets
1 router (192.168.1.1) 0.231 ms 0.161 ms 0.140 ms
2 xe-3-1-2-sur03.michiaganave.dc.bad.comcast.net (68.85.147.53) 8.545 ms 10.429 ms 5.817 ms
3 ae-5-0-ar01.capitolhghts.md.bad.comcast.net (68.86.204.205) 10.104 ms 18.569 ms 17.452 ms
4 ae13-ar01.capitolhghts.md.bad.comcast.net (68.87.168.61) 10.066 ms 9.918 ms 8.437 ms
5 be-33657-cr02.ashburn.va.ibone.comcast.net (68.86.90.57) 14.305 ms 16.196 ms 12.931 ms
6 hu-0-11-0-5-pe07.ashburn.va.ibone.comcast.net (68.86.85.102) 10.991 ms 8.561 ms 8.846 ms
7 as16509-5-c.ashburn.va.ibone.comcast.net (50.242.148.66) 8.680 ms 13.423 ms 12.771 ms
8 54.239.108.138 (54.239.108.138) 49.731 ms 54.239.108.140 (54.239.108.140) 19.008 ms 54.239.108.38 (54.239.108.38) 25.151 ms
9 54.239.111.41 (54.239.111.41) 11.100 ms 54.239.108.235 (54.239.108.235) 11.553 ms 54.239.111.45 (54.239.111.45) 15.408 ms
10 205.251.245.250 (205.251.245.250) 11.559 ms 205.251.244.205 (205.251.244.205) 13.629 ms 205.251.244.207 (205.251.244.207) 11.412 ms
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 s3-1-w.amazonaws.com (52.216.81.112) 10.512 ms 9.974 ms 11.441 ms
Was there ever any resolution to this?
