!Urgent! filename.extension wrong
princeft
First post
Post by princeft »
I noticed in the last version of HBS3 that when backing up my data all filenames are loaded incorrectly.
For example document.pdf becomes ocumentLg==pdf.
I tried to upload the same file from amazon's aws console and the file name was loaded correctly. The same file within the backup process undergoes the change in the file name
This is very terrible and a serious problem because all extensions of the uploaded files are lost.
P3R
Re: !Urgent! filename.extension wrong
Post by P3R »
This user community can't fix bugs, please contact Qnap support.
Return to “Amazon S3”
